Problem with the convergence of the solver
Old   July 23, 2015, 07:05
Default Problem with the convergence of the solver
DOliveira is on a distinguished road
Hi everyone. I'm new with dealing with OpenFoam. I'm trying to simulate a running turbine. When running pimpleDyMFoam I'm having a problem with convergence I think. my fvSolution is the following:
solvers
p
solver GAMG;
tolerance 1e-04;
relTol 0.01;
smoother GaussSeidel;
cacheAgglomeration true;
nCellsInCoarsestLevel 10;
agglomerator faceAreaPair;
mergeLevels 1;
pFinal
solver GAMG;
tolerance 1e-04;
reTol 0;
mergeLevels 1;
cellMotionU
solver GAMG;
tolerance 1e-04;
reTol 0;
mergeLevels 1;
"(U|k|omega)"
solver PBiCG;
preconditioner DILU;
tolerance 1e-04;
relTol 0.1;
"(U|k|omega)Final"
$U;
tolerance 1e-04;
relTol 0;
k
solver PBiCG;
relTol 0.1;
kFinal
solver PBiCG;
tolerance 1e-04;
relTol 0;
PIMPLE
nOuterCorrectors 25;
nCorrectors 1;
nNonOrthogonalCorrectors 0;
pRefCell 0;
pRefValue 0;
relaxationFactors
fields
equations
"U.*" 1;
"k.*" 1;
"omega.*" 1;
My deltaT is 0.01 and my maxCo is 0.7
When running pimpleDyMFoam this error appears:
--> FOAM FATAL IO ERROR:
[1] wrong token type - expected Scalar, found on line 0 the word 'nan'
I think this is because the solver can't find convergence to solve the problem.
Can anyone help me or give some hints on how solve this?
Thank you so much
Daniela
DOliveira is offline   Reply With Quote
Old   July 23, 2015, 07:59
anonymous
ssss is on a distinguished road
We need more information of the error. Second, your fvSolution is awful, please read the documentation of the linear solvers and the PIMPLE argument and use the fvSolution found in the tutorial's testcases
ssss is offline   Reply With Quote
Old   July 23, 2015, 09:13
Thank you for your answer and help. So I've changed my fvSolution.
solvers
p
solver GAMG;
tolerance 1e-2;
relTol 0;
smoother DICGaussSeidel;
cacheAgglomeration no;
mergeLevels 1;
maxIter 50;
pFinal
solver GAMG;
tolerance 1e-6;
reTol 0;
mergeLevels 1;
cellMotionU
solver PCG;
preconditioner DIC
tolerance 1e-08;
reTol 0;
"(U|k|omega)"
solver PBiCG;
tolerance 1e-05;
relTol 0.1;
"(U|k|omega)Final"
$U;
tolerance 1e-05;
relTol 0;
k
solver PBiCG;
relTol 0.1;
kFinal
solver PBiCG;
tolerance 1e-05;
relTol 0;
PIMPLE
correctPhi no;
nOuterCorrectors 3;
nCorrectors 1;
pRefCell 0;
pRefValue 0;
relaxationFactors
fields
equations
"U.*" 1;
"k.*" 1;
"omega.*" 1;
The problem now is that the time steps, deltaT, is too small (in the order of 8e-07) and the No Iterations is constatly 0 (zero)
Do you have any idea why this happens?
Old   November 9, 2015, 12:25
KateEisenhower is on a distinguished road
did you solve your problem? I had a real quick look at the files. You have a typo: Sometimes you write reTol where it should be relTol. Don't know if it is related to your problem though.
Best regards,
Kate
KateEisenhower is offline   Reply With Quote
convergence, dynamic grid, pimpledymfoam
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
convergence of density-based solver for unsteady flow zhengjg Main CFD Forum 0 June 16, 2014 12:37
convergence of density-based solver for unsteady flow zhengjg FLUENT 0 June 16, 2014 11:16
Convergence problem with simpleFoam solver on tilted channel daev OpenFOAM Running, Solving & CFD 1 December 23, 2010 17:20
convergence problem limseokmin FLUENT 3 November 14, 2004 13:43
