July 21, 2015, 11:19 |
Convergence problem on Laplace equation
Rep Power: 19 |
I'm trying to solve a (time independent) Laplace equation, where the solution should be defined by the boundaries only, and not by the initial field.
The solver reaches the desired residual after a specific number of steps. However, the result isn't correct yet, I need to run the solver a few more times until I get a converged result. The final residual will be similar all the time, but the initial residual on a consecutive solve doesn't equal the previous final residual (it's much higher and dropping with each solver execution). When I have executed the solver a sufficient number of times, equation solver iterations will go to zero and the initial residual won't improve anymore. So: 1) Why don't the final and initial residuals of consecutive runs match? Is this related to the iterative nature of the matrix solvers? 2) Why don't I get a converged result after the first iteration, even though the final residual of all iterations is on a similar scale? Is the equation solver converging in some local minimum that has a similar final residual than the correct result? 3) I'm using an unstructered mesh. Is this problem related to non-orthogonality correction for the pressure equation, which is also solved multiple times? 4) Is it reasonable to put the equation solving in a loop until the initial residual doesn't improve anymore? I would be glad for some pointers here. |
July 23, 2015, 10:41 |
Rep Power: 19 |
I'm now pretty sure that this is the same effect that is happening on the non-orthogonality correction for the pressure equation, given that they also use a laplacian and just solve the equation a few times without doing anything else.
So, is this just a thing that needs to be handled by experience using a constant number of solve() calls? Or is it better to monitor the initial residuals until convergence? |
November 23, 2022, 21:27 |
The same question
Ding Yan
Rep Power: 4 |
I know it has been a long time. I meet the same question these days. how to solve this question! Thank you very much! |
October 6, 2023, 11:46 |
#4 | |||
Mohammed Sayyari
I know this is way way late and you probably figured it out by now, but here are a few thoughts
Yes, if that's what you are looking for, typically, you want to drive it up to a specific residual in your mind. Not necessarily until it doesn't change, but that would be the best case. This would be costly, though. |
[ICEM] issue occur after extrude 2D airfoil mesh and convergence problem in CFX | shiyun | ANSYS Meshing & Geometry | 4 | May 9, 2012 20:55 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 23:03 |
Convergence problem of the energy equation | Woo Meng Wai | FLUENT | 2 | May 13, 2008 04:06 |
convergence problem | limseokmin | FLUENT | 3 | November 14, 2004 13:43 |
