compressible solver rhosimplefoam "sigFe" error |
July 17, 2015, 21:07 |
Ruby Qian
Rep Power: 13 |
Hi everyone
I'm trying to simulate a flow field around a helicopter blade in hover using rhoSimpleFoam/rhoSimplecFoam. The version is OF-2.2.2 . But I keep getting this error in 2 interations. Code:
Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 1e-05 field U tolerance 1e-06 field h tolerance 0.001 field "(k|omega)" tolerance 1e-05 Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport sutherland; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting RAS turbulence model kOmegaSST kOmegaSSTCoeffs { alphaK1 0.85034; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.85616; Prt 1; gamma1 0.5532; gamma2 0.4403; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; } Creating fintite volume options from fvOptions Selecting finite volume options model type MRFSource Source: MRF1 - applying source for all time - selecting cells using cellZone MRF-cells - selected 17644240 cell(s) with volume 21.2025 Starting time loop forces forces: Time = 0.01 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.009296, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.012759, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.0126077, No Iterations 2 DILUPBiCG: Solving for h, Initial residual = 0.510074, Final residual = 0.00850355, No Iterations 1 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.00993348, No Iterations 170 DICPCG: Solving for p, Initial residual = 6.77265e-05, Final residual = 9.45422e-07, No Iterations 72 DICPCG: Solving for p, Initial residual = 3.33876e-05, Final residual = 9.58751e-07, No Iterations 35 time step continuity errors : sum local = 4.33681e-06, global = -6.56944e-08, cumulative = -6.56944e-08 rho max/min : 2 0.5 DILUPBiCG: Solving for omega, Initial residual = 0.0144652, Final residual = 0.000953703, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 0.999988, Final residual = 0.0653421, No Iterations 1 ExecutionTime = 485.77 s ClockTime = 486 s Time = 0.02 DILUPBiCG: Solving for Ux, Initial residual = 0.714487, Final residual = 0.00670596, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.14934, Final residual = 0.00132467, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.715737, Final residual = 0.071483, No Iterations 1 DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 0.07682, No Iterations 1 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 in "/lib64/libc.so.6" #3 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() at ??:? #4 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::correct() at ??:? #5 at ??:? #6 __libc_start_main in "/lib64/libc.so.6" #7 at ??:? # Here are my p and U files p Code:
dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1.0e5; boundaryField { "blade.*" { type zeroGradient; } "top.*" { /*type totalPressure; p0 uniform 102152; U U; phi phi; rho none; psi none; gamma 1.4; value uniform 102152;*/ type zeroGradient; } "far|bottom.*" { type fixedValue; value $internalField; /* type totalPressure; p0 uniform 98564; U U; phi phi; rho none; psi none; gamma 1.4; value uniform 98564;*/ } } Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0.0 0 0); boundaryField { "blade.*" { type fixedValue; value uniform (0 0 0); } "top.*" { type fixedValue; value uniform (0 0 0); /*type pressureInletOutletVelocity; value uniform (0 0 0);*/ } "far|bottom.*" { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); /*type pressureInletOutletVelocity; value uniform (0 0 0); */ } } Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; grad(p) faceLimited leastSquares 1; //cellLimited Gauss linear 1; //Gauss linear; grad(U) faceLimited leastSquares 1; } divSchemes { default none; div(phi,U) Gauss upwind; //div(phi,U) Gauss linearUpwind grad(U); div(phi,k) Gauss upwind; div(phi,omega) Gauss upwind; div((nuEff*dev(T(grad(U))))) Gauss upwind; //linear; div((muEff*dev2(T(grad(U))))) Gauss linear; div(phi,Ekp) Gauss upwind; div(phi,h) Gauss upwind; //limitedLinear 1; div(phi,e) Gauss upwind; //limitedLinear 1; div(phi,K) Gauss linear; /*div(phi,U) Gauss limitedLinearV 1; div(phi,h) Gauss limitedLinear 1; div(phi,k) Gauss limitedLinear 1; div(phi,omega) Gauss limitedLinear 1; div((muEff*dev2(T(grad(U))))) Gauss linear; div(phi,K) Gauss linear;*/ } laplacianSchemes { default Gauss linear limited 0.33; } interpolationSchemes { default linear; } snGradSchemes { default corrected; //limited 0.33; } fluxRequired { default no; pcorr ; p ; } Code:
solvers { rho { solver PCG; preconditioner DIC; tolerance 1e-5; relTol 0.1; } rhoFinal { $rho; tolerance 1e-5; relTol 0; } p { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0.01; } U { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } k { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } omega { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } "(e|h|R)" { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } nuTilda { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } } SIMPLE { nNonOrthogonalCorrectors 2; rhoMin rhoMin [ 1 -3 0 0 0 ] 0.5; rhoMax rhoMax [ 1 -3 0 0 0 ] 2.0; residualControl { p 1e-5; U 1e-6; h 1e-3; "(k|omega)" 1e-5; } } relaxationFactors { fields { /*p 0.2; rho 0.05;*/ } equations { U 0.7; k 0.7; omega 0.7; R 0.7; nuTilda 0.7; h 0.7; } } Can anyone help me please? I've been struggled for days. Last edited by wyldckat; July 18, 2015 at 17:58. Reason: Added [CODE][/CODE] markers |
July 17, 2015, 21:10 |
Ruby Qian
Rep Power: 13 |
sorry about the code format mess .
something wrong with my ie , i can't get a response on the quote or # botton. sorry again. and please help. |
January 7, 2019, 04:24 |
Bidesh Sengupta
Rep Power: 8 |
I am having few problems. Although residuals are quite low and no out of bounds still: Code:
Courant Number mean: 3.35064e-13 max: 0.301157 deltaT = 1.90835e-11 Time = 0.546089 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 3.56934e-12, Final residual = 3.56934e-12, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 3.52604e-12, Final residual = 3.52604e-12, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 4.2873e-12, Final residual = 4.2873e-12, No Iterations 0 smoothSolver: Solving for h, Initial residual = 9.95909e-06, Final residual = 9.95909e-06, No Iterations 0 GAMG: Solving for p, Initial residual = 5.94342e-12, Final residual = 5.94342e-12, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 6.25413e-14, global = -4.70952e-15, cumulative = -4.0427e-07 GAMG: Solving for p, Initial residual = 5.94342e-12, Final residual = 5.94342e-12, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 6.25414e-14, global = -4.70952e-15, cumulative = -4.0427e-07 smoothSolver: Solving for epsilon, Initial residual = 2.97988e-09, Final residual = 2.97988e-09, No Iterations 0 smoothSolver: Solving for k, Initial residual = 5.14549e-07, Final residual = 5.14549e-07, No Iterations 0 ExecutionTime = 22051.5 s ClockTime = 22078 s Courant Number mean: 3.33784e-13 max: 0.301157 deltaT = 1.90102e-11 Time = 0.546089 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 3.56857e-12, Final residual = 3.56857e-12, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 3.52543e-12, Final residual = 3.52543e-12, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 4.2808e-12, Final residual = 4.2808e-12, No Iterations 0 smoothSolver: Solving for h, Initial residual = 1.0036e-05, Final residual = 5.10147e-08, No Iterations 1 [1] #0 Foam::error::printStack(Foam::Ostream&)[2] #0 Foam::error::printStack(Foam::Ostream&) at ??:? at ??:? [1] #1 [2] #1 Foam::sigFpe::sigHandler(int)Foam::sigFpe::sigHandler(int) at ??:? [2] #2 ? at ??:? [1] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [2] #3 Foam::hePsiThermo<Foam::psiThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() in "/lib/x86_64-linux-gnu/libc.so.6" [1] #3 Foam::hePsiThermo<Foam::psiThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() at ??:? [2] #4 Foam::hePsiThermo<Foam::psiThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::correct() at ??:? [1] #4 Foam::hePsiThermo<Foam::psiThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::correct() at ??:? [2] #5 ? at ??:? [1] #5 ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam" [2] #6 __libc_start_main in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam" [1] #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [2] #7 ? in "/lib/x86_64-linux-gnu/libc.so.6" [1] #7 ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam" [bidesh:03000] *** Process received signal *** [bidesh:03000] Signal: Floating point exception (8) [bidesh:03000] Signal code: (-6) [bidesh:03000] Failing at address: 0x3e800000bb8 [bidesh:03000] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f1b958d3f20] [bidesh:03000] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7f1b958d3e97] [bidesh:03000] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f1b958d3f20] [bidesh:03000] [ 3] /opt/openfoam6/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_16sensibleEnthalpyEEEEEEEE9calculateEv+0x2b6)[0x7f1b9c3b4ac6] [bidesh:03000] [ 4] /opt/openfoam6/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_16sensibleEnthalpyEEEEEEEE7correctEv+0x2a)[0x7f1b9c3cfc1a] [bidesh:03000] [ 5] /opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam(+0x2ef91)[0x55e7b6cb1f91] [bidesh:03000] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f1b958b6b97] [bidesh:03000] [ 7] /opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam(+0x36eca)[0x55e7b6cb9eca] [bidesh:03000] *** End of error message *** in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam" [bidesh:03004] *** Process received signal *** [bidesh:03004] Signal: Floating point exception (8) [bidesh:03004] Signal code: (-6) [bidesh:03004] Failing at address: 0x3e800000bbc [bidesh:03004] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f1cce2cbf20] [bidesh:03004] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7f1cce2cbe97] [bidesh:03004] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f1cce2cbf20] [bidesh:03004] [ 3] /opt/openfoam6/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_16sensibleEnthalpyEEEEEEEE9calculateEv+0x2b6)[0x7f1cd4dacac6] [bidesh:03004] [ 4] /opt/openfoam6/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_16sensibleEnthalpyEEEEEEEE7correctEv+0x2a)[0x7f1cd4dc7c1a] [bidesh:03004] [ 5] /opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam(+0x2ef91)[0x56316ef7af91] [bidesh:03004] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f1cce2aeb97] [bidesh:03004] [ 7] /opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam(+0x36eca)[0x56316ef82eca] [bidesh:03004] *** End of error message *** ^Cmpirun: abort is already in progress...hit ctrl-c again to forcibly terminate I have initialized k and epsilon according to: k/(U*U)=1e-6, epsilon*charecteristic length of object/(U*U*U)=4.5e-7 [Ref: https://www.simscale.com/forum/t/ini...cients/25950/7 I shall be grateful if anyone can help me out. Thank you. Last edited by wyldckat; January 8, 2019 at 17:08. Reason: Added [CODE][/CODE] markers |
January 8, 2019, 17:12 |
#5 | ||
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: Partially quoting myself from a recent post of mine:
[2] #3 Foam::hePsiThermo<Foam::psiThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() in "/lib/x86_64-linux-gnu/libc.so.6" [1] #3 Foam::hePsiThermo<Foam::psiThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() at ??:? Quote:
Furthermore, the very small time steps and the very small residual values lead me to suspect that something very wrong is happening in your case, so I really suspect that you are using a pressure value of zero somewhere. It would be as if you suddenly placed your mesh in outer space and the air around escaped at a tremendous speed.
January 8, 2019, 19:36 |
Bidesh Sengupta
Rep Power: 8 |
Thank you very much for your suggestion. I shall look into it the way you said.
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 05:34 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 20:16 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
