Run-time error in icoUncoupledKinematicParcelFoam with stochasticDispersion model
Old   July 9, 2015, 15:55
Default Run-time error in icoUncoupledKinematicParcelFoam with stochasticDispersion model
Nadish Saini
90nash is on a distinguished road
Hello all,
I am trying to run a case to simulate particles in an already solved steady state flow field with icoUncoupledKinematicParcelFoam solver. The case is running fine if i do not select any dispersion model but if i choose stochasticDispersionRAS, the solver gives the below error. I am not able to figure out why.
Starting time loop
Time = 0.0001
Evolving kinematicCloud
Solving 3-D cloud kinematicCloud
--> FOAM FATAL ERROR:
Not implemented
From function Foam::vector Foam:ispersionModel<CloudType>::update(const scalar, const label, const vector&, const vector&, vector&, scalar&)
in file lnInclude/DispersionModel.C at line 90.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam:ispersionModel<Foam::KinematicCloud<Foam::C loud<Foam::CollidingParcel<Foam::KinematicParcel<F oam:article> > > > >::update(double, int, Foam::Vector<double> const&, Foam::Vector<double> const&, Foam::Vector<double>&, double&) at ??:?
at ??:?
at ??:?
at ??:?
at ??:?
at ??:?
at ??:?
at ??:?
at ??:?
#11 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#12
at ??:?
^CAborted (core dumped)
I am also attaching the kinematicCloudProperties file for reference. Please help me out.!!
90nash is offline   Reply With Quote
Old   July 9, 2015, 15:56
Nadish Saini
I forgot to mention i am running the case on OpenFOAM v2.3.1
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 10:08
How to export time series of variables for one point? mary mor OpenFOAM Post-Processing 8 July 19, 2017 11:54
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Transient run continues from last time (when startover is desired) bongbang CFX 2 March 23, 2015 00:05
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
