DES, DDES, IDDES for compressible solver rhoCentralFoam |
DongHo
Rep Power: 13 ![]() |
Hi, Foamers
I have been using Hybrid LES/RANS like DES, DDES only for incompressible flows. At this time, I'd like to use Spalart-Allmara DDES or k-w SST DDES (implemented by me) with rhoCentralFoam in OpenFOAM v2.30. I want to know if I can still use those Hybrid models for compressible solvers without any modifications or additional works. Also, I will appreciate it if anyone has an example file using SAS turbulence model and can share it with me. Thank you. P.S: I remember k-w SST-DDES I implemented was for incompressible flows. By the way, I can still use it for a compressible solver like rhoCentralFoam only by changing "namespace incompressible" into "namespace compressible" in source files and compiling them again? Otherwise, should I modify many portions in source files for compressible solvers? Last edited by eddykendo; July 9, 2015 at 11:13. |
Hi
Which shielding function did you use for the kw-SST DDES? |
#3 | |
王莹
Rep Power: 9 ![]() |
Could you please share the SST DDES code? I am trying to modify the DDES model in openfoam, but I can't find a ready-made SST-DDES in of5. Besides, do you know something about the definition of 'delta' in DDES? Theoretically, it is a variable about deltax, delaty and deltz, which are sizes of mesh in three directions. However, I can not find the definition code mentioning these three paramenters. Thanks a lot! Anyone who can give me ideas is welcome! Alisa. Quote:
Boucetta Lahcene
Rep Power: 4 ![]() |
Hello everybodydo
Do you find the sst DDES code, I really need it for my intership I'm looking everywhere but I find the IDDES spalart-allmaras It would be nice of you if someone could share it or tell me what implementation I should do. Gracias |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
Getting too many iterations by velocity solving (aborting). Changing U - Solver? | suitup | OpenFOAM Running, Solving & CFD | 0 | January 20, 2010 07:45 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
Setting a B.C using UserFortran in 4.3 | tokai | CFX | 10 | July 17, 2001 16:25 |
