Arsalan
Rep Power: 12 ![]() |
Dear Foamers,
I want to study the shape oscillation an translation motion of a single bubble in a liquid container under vibration while the imposed displacement of the container is y=Acos(wt). I found that there are two methods for this purpose,first i used the interDyMFoam solver with oscillatingLinearMotion as the solidBodyMotionFunction,but with this method i get very wrong results in the bubble shape and motion. Then i add an acceleration source term to the interFoam solver with modifying the UEqn.H file : dimensionedVector accY ( "accY",dimensionSet(0, 1, -2, 0, 0),vector(0, 1, 0) ); scalar Pi = 3.14; dimensionedVector acc = (-(w^2)*A*Foam::cos(w*runTime.value())*accY); fvVectorMatrix UEqn ( fvm::ddt(rho, U) + fvm::div(rhoPhi, U) + turbulence->divDevRhoReff(rho, U) == (acc*rho) ); UEqn.relax(); if (pimple.momentumPredictor()) { solve ( UEqn == fvc::reconstruct ( ( fvc::interpolate(interface.sigmaK())*fvc::snGrad(a lpha1) - ghf*fvc::snGrad(rho) - fvc::snGrad(p_rgh) ) * mesh.magSf() ) ); } with this method bubble shape and oscillaton in the first time steps are good but the velocity magnitude is wrong and bubble shape and oscillation by the time get wrong results,im not sure that the UEqn.H file is modified correct or not,or which method is suitable for the forced vibration of the container,so far i couldnt find an answer for this problems!what is the difference between two methods and why the first method get wrong results?! I would appreciate your comments! Thanks a lot, Arsalan. |
Arsalan
Does nobody has a suggestion or idea??
I would be very much thankful.. |
bubble dynamics, dynamic mesh, interdymfoam, interfoam, moving mesh |
A rising bubble in a stagnant liquid with two-fluid-model | fs82 | OpenFOAM Running, Solving & CFD | 30 | August 18, 2016 12:27 |
2D bubble rising through a column of water | vof64 | Fluent Multiphase | 0 | August 19, 2014 23:42 |
Coupled VOF and Multiphase Segregated Flow for a gas bubble problem?? | EnronZhang | STAR-CCM+ | 1 | December 19, 2013 08:41 |
Query on VOF for Bubble rise | Vamsi | Main CFD Forum | 0 | December 22, 2005 00:02 |
