LES of channel flow: data, case files, technical report. |
August 13, 2019, 05:46 |
#21 |
Rep Power: 12 |
Nice! Thank you!
May 31, 2020, 12:35 |
#22 |
Arijit Saha
Rep Power: 7 |
Respected Sir, it was so nice of you to share this topic here at CFD Forum. I am a newbie in OpenFoam and trying my best to learn most out of it but most of the time I suffer in finding the proper answer to my doubt in google.
Anyway I was doing some research with Channel 395 case with some modification like the boundary condition. In an unchanged channel flow the U and p folder look like the attachment shared along with this post. From my obserservation what I depicted is as follows:- 1.Bottom and top wall is having a no-slip boundary condition. 2. The solution has been provided with some initial condition i.e for 60000 cells they have provided some initial values. 3. The flow that is coming out of outlet is again fed to inlet and in this way the cycle goes on. What I didnt understand is what is the significance of the side using it as a cyclic boundary condition? Once I m clear with this part then I ll aim for my next target that is feeding some surface value to the inlet patch using mapped field and run the simulation. So in what way can I modify the bc in order to feed the inlet patch with some predefined value instead of the flow coming out from the outlet? |
June 1, 2020, 06:08 |
#23 | |
Timofey Mukha
Rep Power: 14 |
The idea is that the domain is infinite in the wall-parallel directions. We simulate that with cyclic boundaries. If you have walls on the side, that is going to lead to different results, since you'd have associated velocity gradients etc. Regarding changing the boundary to some sort of inlet, it depends on what you intend to "feed". In any case, you put some sort of Dirichlet bc for U and zeroGradient for the pressure at the inlet, and the outlet set pressure to 0 and zeroGradient for velocity. |
June 1, 2020, 06:23 |
#24 | |
Arijit Saha
Rep Power: 7 |
Also attached with this post is the boundary field which I m trying to feed to the inlet, u can have a look. |
June 1, 2020, 07:12 |
#25 | |
Timofey Mukha
Rep Power: 14 |
If you'll have an inlet and an outlet then initial conditions don't matter that much at all, they will be flushed out of the domain pretty fast anyway. |
June 1, 2020, 09:56 |
#26 |
Arijit Saha
Rep Power: 7 |
Do you have any idea how can I make it working?
June 4, 2020, 04:26 |
#27 |
Timofey Mukha
Rep Power: 14 |
I'm sorry but I don't really understand what the problem is.
December 28, 2022, 13:13 |
#28 |
chandra shekhar pant
Rep Power: 17 |
Hi @Tiam,
Thanks for your paper and the codes that you shared, it's a very old post, so not sure, if it's still active. I am also trying to perform LES of Re_tau = 180 for channel flow in a little bit bigger domain, by imposing the pressure gradient using fvoptions and calculating the pressure gradient as Code:
u_\tau^2/h and calculating u_\tau using the Re_\tau value, since h is known, viscosity I predefined for my simulations. Unfortunately I am unable to see any turbulence in my simulations, could you please share your 0 folder? I assume that when you started your simulations it could have been started from 0 time. Any comment or suggestion would be welcomed, many thanks in advance. |
December 28, 2022, 14:15 |
#29 | |
Timofey Mukha
Rep Power: 14 |
180 is difficult to make turbulent. I recommend that you change viscosity and run at a higher Re for a bit, just to get turbulence. Than u can switch tje viscosity back. Also, be ready that when u set the p gradient instead of Ub, it takes a lobger time to reach a statistically steady state. |
December 29, 2022, 04:48 |
#30 |
Rep Power: 17 |
Hello
Good morning, many thanks for your prompt reply, but is there anything I can do to trigger the turbulence by boundary condition or initial condition? To save time for getting the statistically stationery state, I am using simpleFoam to get converged results and then mapping the fields to LES solver, it this fine ? Any further help would be very much appreciated, thanks in advance. |
December 29, 2022, 05:19 |
#31 | |
Rep Power: 12 |
you should artificially introduce turbulence to the flow. There is an utility written by Eugene de Villiers that modifies the initial velocity flow in order to trigger turbulent motion in the channel. Basically, the utility will modify the initial velocity field near the wall boundary to mimic the coherent vortex-like structures based on the paper mentioned in the utility code. I tested it and it works just fine. But have in mind that you should probably modify code depending on the distribution of OpenFoam you use in order to compile it. Find utility attached to this post. I hope this will help you with your work. Best regards. |
December 29, 2022, 12:49 |
#32 |
Rep Power: 17 |
Thanks a lot Camel for your wonderful and helpful comment. I was trying to install it, but after unziping your sent zip file, i could see that it contain Make directory, perturbU.c and perturbUDict, could you please elaborate how to install and use it. I am using OpenFOAM v1906 and/or v2112. Any further comments/suggestions would be very much appreciated, many thanks in advance.
December 30, 2022, 06:15 |
#33 |
Rep Power: 17 |
Hi again Camel,
Many thanks for your help in this forum, could you please help me to use the utility perturbU in the OF v1906/v2112. How to install/use this utility, I am still stuglling to get turbulence for the channel flow Re_\tau = 180, with specified pressure gradient condition. I managed to get the steady state solution from RANS, using that I am trying to run LES case. I used WALE scheme for LES but unfortunately seems like that is killing turbulence, thus now switching towards the KEqn model. If this utility could help, then it would save enormous amount of time, hope you understand and will help me, thanks in advance. |
March 27, 2023, 01:25 |
channel395 tutorial case
#34 |
iraza
Rep Power: 3 |
Hi Timofey,
I have been trying to run channel395 tutorial case to reproduce the moser’s results at Re_tau=180 initially. I used to run it till t=10s. I also tried to run this case till t=2000s but results were similar as for t=10s. In this tutorial, there are folders like 0 and 0.orig, so I used 0.orig for my simulations. However, I could not reproduce moser’s results yet. I have visited https://bitbucket.org/lesituu/channel_flow_data/ and there is a folder named initial_conditions which does not readable, however, other folders can be readable. Would you (or others) please share the initial_conditions folder again so that I can read it. Regards, |
June 12, 2023, 09:11 |
#35 |
Emeline Noel
Rep Power: 13 |
Thank you for sharing your work ! Useful !
channel flow, les, swak4foam |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
UDF issue | MASOUD | Fluent UDF and Scheme Programming | 14 | December 6, 2012 14:39 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 08:21 |
PhD in turbulence | Hans | Main CFD Forum | 14 | October 8, 2001 04:03 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
