potentialFoam doesnt start?!
Old   July 2, 2015, 08:48
Default potentialFoam doesnt start?!
Sway is on a distinguished road
hey!
i got this error befor and after including potentialFoam to my fsSolution, anybody knows why potentialFoam does not work? Is it an BC error? Im new to OF and pretti much guesing may way trough...-.-
|  \\    /   O peration     | Version:  2.4.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.4.0-dcea1e13ff76
Exec   : pisoFoam -parallel
Date   : Jul 02 2015
Time   : 13:37:31
Host   : "bps"
PID    : 6606
Case   : /home/bps/OpenFOAM/bps-2.4.0/run/Test_D25_piso
nProcs : 8
Slaves :
7
"bps.6607"
"bps.6608"
"bps.6609"
"bps.6610"
"bps.6611"
"bps.6612"
"bps.6613"
Pstream initialized with:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    sigmaEps        1.3;
Starting time loop
Time = 0.0001
Courant Number mean: 0.00639733 max: 0.624297
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.00336371, No Iterations 1000
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.00516443, No Iterations 1000
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.00517576, No Iterations 1000
[0]
[0]
[0] --> FOAM FATAL ERROR:
[0] Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux              : 0.0318552
Specified mass inflow   : 9.5206e-20
Specified mass outflow  : 0.0049
Adjustable mass outflow : 0
[0]
[0]
[0]     From function adjustPhi(surfaceScalarField&, const volVectorField&,volScalarField&)
[0]     in file cfdTools/general/adjustPhi/adjustPhi.C at line 114.
[0]
FOAM parallel run exiting
[0]
[2]
[2]
[2] --> FOAM FATAL ERROR:
[2] Continuity error cannot be removed by adjusting the outflow.
[2]
[2]
[2]     From function adjustPhi(surfaceScalarField&, const volVectorField&,volScalarField&)
[2]     in file cfdTools/general/adjustPhi/adjustPhi.C at line 114.
[2]
[2]
[5]
[5]
[5] --> FOAM FATAL ERROR:
[5] Continuity error cannot be removed by adjusting the outflow.
[5]
[5]
[5]     From function adjustPhi(surfaceScalarField&, const volVectorField&,volScalarField&)
[5]     in file cfdTools/general/adjustPhi/adjustPhi.C at line 114.
[5]
[5]
[7]
[7]
[7] --> FOAM FATAL ERROR:
[7] Continuity error cannot be removed by adjusting the outflow.
[7]
[7]
[7]     From function adjustPhi(surfaceScalarField&, const volVectorField&,volScalarField&)
[7]     in file cfdTools/general/adjustPhi/adjustPhi.C at line 114.
[7]
[7]
[1]
[1]
[1] --> FOAM FATAL ERROR:
[1] Continuity error cannot be removed by adjusting the outflow.
[1]
[1]
[1]     From function adjustPhi(surfaceScalarField&, const volVectorField&,volScalarField&)
[1]     in file cfdTools/general/adjustPhi/adjustPhi.C at line 114.
[1]
[1]
[3]
[3]
[3] --> FOAM FATAL ERROR:
[3] Continuity error cannot be removed by adjusting the outflow.
[3]
[3]
[3]     From function adjustPhi(surfaceScalarField&, const volVectorField&,volScalarField&)
[3]     in file cfdTools/general/adjustPhi/adjustPhi.C at line 114.
[3]
[3]
[4]
[4]
[4] --> FOAM FATAL ERROR:
[4] Continuity error cannot be removed by adjusting the outflow.
[4]
[4]
[4]     From function adjustPhi(surfaceScalarField&, const volVectorField&,volScalarField&)
[4]     in file cfdTools/general/adjustPhi/adjustPhi.C at line 114.
[4]
[4]
MPI_ABORT was invoked on rank 7 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[6]
[6]
[6] --> FOAM FATAL ERROR:
[6] Continuity error cannot be removed by adjusting the outflow.
[6]
[6]
[6]     From function adjustPhi(surfaceScalarField&, const volVectorField&,volScalarField&)
[6]     in file cfdTools/general/adjustPhi/adjustPhi.C at line 114.
[6]
[6]
mpirun has exited due to process rank 7 with PID 6613 on
node bps exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
[bps:06605] 7 more processes have sent help message help-mpi-api.txt / mpi-abort
[bps:06605] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
fvSolution:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver          GAMG;
        tolerance       1e-06;
        relTol          0.1;
        smoother        GaussSeidel;
        nPreSweeps      0;
        nPostSweeps     2;
        cacheAgglomeration on;
        agglomerator    faceAreaPair;
        nCellsInCoarsestLevel 10;
        mergeLevels     1;
    pFinal
        $p;
        tolerance       1e-06;
        relTol          0;
    "(U|k|epsilon|R|nuTilda)"
        solver          smoothSolver;
        tolerance       1e-05;
        relTol          0;
PISO
    nCorrectors     2;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
potentialFlow
    nNonOrthogonalCorrectors 10;
Sway is offline   Reply With Quote
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 07:55
Sample not working correctly sihaqqi OpenFOAM Running, Solving & CFD 1 July 12, 2014 02:36
Partition does not start on physical sector boundary!!?? immortality Lounge 1 December 8, 2013 16:04
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
