Sig Turbomachinery Library in OpenFoam 2.3.1 and libsixDoFRigidBodyMotion
Old   June 24, 2015, 15:18
Default Sig Turbomachinery Library in OpenFoam 2.3.1 and libsixDoFRigidBodyMotion
v.pilechi is on a distinguished road
I am modeling a tidal turbine using AMI approach, pympleDyMFoam solver and "libsixDoFRigidBodyMotion" library in the dynamic mesh dictionary.
I would like to have the axial power of the turbine, torque and rotational speed as the output. I tried to use Sig Turbomachinery Library for that purpose from
https://github.com/wyldckat/OSIG-Tur...formance-OF2.x
However, I was not successful as it seems that this library is designed to work with the constant rotational speed ("omega") which is not the case in my model as the turbine is deriven by the flow and the rotational speed is variable base on the water velocity.
When I run the model using Sig Turbomachinery Library the turboPerformance.dat file is generated but it is empty. Also the model only work if "Uname Uabs" and not with
"Uname U".
I appreciate your help in advance.
Best Regards,
Vahid
v.pilechi is offline   Reply With Quote
sigturbomachinery, sixdofrigidbodymotion, torque coefficient, turbine
[OpenFOAM.org] Problems installing OpenFOAM 2.3.1 in Ubuntu 12.04 masoudshao OpenFOAM Installation 10 August 9, 2018 07:13
[OpenFOAM.org] Installation of OpenFOAM 2.3.1 on RHEL 6.3 Turbulent OpenFOAM Installation 2 March 26, 2015 04:32
OpenFOAM Foundation releases OpenFOAMŪ 2.3.1 CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 4 February 8, 2015 06:19
Trouble with sampleDict syntax for OpenFOAM 2.3.1 rawdoggity OpenFOAM Post-Processing 1 February 1, 2015 06:24
OpenFOAM 2.0.0 and Turbomachinery lindner OpenFOAM 0 July 8, 2011 08:35
