June 24, 2015, 01:15 |
Round Value - SetFields
Xavier Pivan
Rep Power: 11 |
Hi
Here is my problem, I set up two differents fluids in a box i a similar case than the DamBreak using settlingfoam solver. I try to set up different range of Alpha value such as 0.02 // 0.01 and 0 for the other fluid - I have no problem. But once I try to set up value such as 0.015 and set up my initial condition with SetFields it rounds the Alpha value to 0.02. Do you guys have any idea if this is possible to avoid this ? Cheers, Xavier |
rhoSimplecFoam with setFields | sino75 | OpenFOAM Pre-Processing | 0 | March 11, 2015 05:08 |
[ICEM] Generate structured mesh for a 3D round surface | Anna Tian | ANSYS Meshing & Geometry | 3 | January 11, 2014 11:15 |
Problems with the execution of the setFields utility. | foamer | OpenFOAM Pre-Processing | 5 | June 3, 2013 13:24 |
setFields tool does not assign water volume for given mesh. | paka | OpenFOAM | 2 | June 7, 2012 10:17 |
Two round jet modeling | shg74 | FLUENT | 0 | February 2, 2010 11:47 |
