June 19, 2015, 07:33 |
Is this kind of study possible in OF?
Rep Power: 14 |
i have a problem which i'm interested to solve within OF. I have a tank domain in which a rotating disc is sitting. The tank is filled with water completly. The rotating discs functions as an aeration for the water. So i want to apply a pressure inlet to the connected disc shaft which then releases small air bubbles through the disc into the tank. I want to model the disc as a membrane (porous medium) so i don't have to model each small hole in the disc. Would this kind of problem be possible to solve with any kind of OF solver or would i need prop. software? I hope i described my problem good enough. Thanks! |
[Other] Difference between Mesh independance study and Mesh Sensitivity Study | kunvd | ANSYS Meshing & Geometry | 4 | September 1, 2016 22:31 |
parametric study with design modeler and icepak | aminem | ANSYS | 3 | May 21, 2014 06:11 |
Best approach to study temporal and spatial convergence | ndabir | Main CFD Forum | 6 | July 16, 2013 11:46 |
[ANSYS Meshing] grid study, important questions | hamid1 | ANSYS Meshing & Geometry | 2 | February 10, 2012 14:28 |
Convergence Rate Study | Khurram | Main CFD Forum | 1 | May 15, 2002 06:05 |
