atmBoundaryLayerInlet, using turbineSiting, resulted in sigFpe
Old   June 18, 2015, 12:18
Default atmBoundaryLayerInlet, using turbineSiting, resulted in sigFpe
Michela
bargiola is on a distinguished road
Hi!
I would like to use atmBoundaryLayerInlet condition in my simulation.
I have utilized the turbineSiting tutorial for the example, but when I run the simulation, I get this error message:
" Create time
Create mesh for time = 0
Reading field p
Reading field U
[0] #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
[0] #1 Foam::sigFpe::sigHandler(int) at ??:?
[0] #2 in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #3 log in "/lib/x86_64-linux-gnu/libm.so.6"
[0] #4 Foam::incompressible::atmBoundaryLayerInletVelocit yFvPatchVectorField::atmBoundaryLayerInletVelocity FvPatchVectorField(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
[0] #5 Foam::fvPatchField<Foam::Vector<double> >::adddictionaryConstructorToTable<Foam::incompres sible::atmBoundaryLayerInletVelocityFvPatchVectorF ield>::New(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
[0] #6 Foam::fvPatchField<Foam::Vector<double> >::New(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
[0] #7 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::readField( Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
[0] #8 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) at ??:?
[0] #9 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields() at ??:?
[0] #10 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) at ??:? [0] #11
[0] at ??:?
[0] #12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #13
[0] at ??:?
Can someone help me? I don't understand where is the error...
Thank you
Last edited by bargiola; June 18, 2015 at 12:20. Reason: I'm working for my thesis
bargiola is offline   Reply With Quote
New! Turbinesiting tutorial bathgooner OpenFOAM Pre-Processing 7 July 29, 2021 00:52
SigFpe when running ANY application in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 23, 2015 15:53
turbineSiting tutorial: slip condition at top boundary gives unexpected result letzel OpenFOAM 0 June 6, 2014 06:25
[snappyHexMesh] Problem with the turbineSiting tutorial and snappyHexMesh Thaemos OpenFOAM Meshing & Mesh Conversion 0 June 28, 2013 05:32
ICC compiler and sigFpe for sample utility cfdmarkus OpenFOAM Installation 3 June 25, 2010 15:31
