Automatic Time Step supported by icoFsiElasticNonLinULSolidFoam? |
June 16, 2015, 14:01 |
Rep Power: 11 |
Hey,
I wonder if automatic time step is supported by the icoFsiElasticNonLinULSolidFoam solver? I have a simulation which crashes due to high Couranr numbers. So, I wanted to set adjustTimeStep to yes and maxCo to 0.5 to make OF take care about the timesteps. But somehow simulations are still defined by deltaT…? Thanks |
June 20, 2015, 06:30 |
Rep Power: 11 |
Sorry for my question, but you use the solver which is very interesting to me. You said that you have the stability problems due to the high Courant number. But my question is: do you have any OTHER problems with solver ? I and some guys here cannot properly run it for even a simple FSI simulations (for example, elastic pipe). Our simulations crashes but it is not because of high Courant number, it's something else... So, do you have a stable and reliable solution of FSI problem or your simulations also crashes ? Maybe you've already find a way how to fix FSI solver...
Thanks |
June 22, 2015, 09:10 |
#3 | |
Rep Power: 11 |
How did you define your time step? Do you use automatic time step or have you defined one manually? |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 05:13 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 14:40 |
Rapidly decreasing deltaT for interDyMFoam | chrisb2244 | OpenFOAM Running, Solving & CFD | 3 | July 1, 2014 17:40 |
Full pipe 3D using icoFoam | cyberbrain | OpenFOAM | 4 | March 16, 2011 10:20 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
