Coupled regions parallel run
Old   June 16, 2015, 10:27
Default Coupled regions parallel run
Loïc Ruan
loic.ruan is on a distinguished road
Dear Foamers,
I am using conjugateHeatSimpleFoam for my coupled heat transfer problem. I got some good results when I am not running in parallel. But as it takes very long, I would like to switch it to parallel.
I tried with the "scotch" decomposition method to split my mesh. It worked, but when I visualized the result in paraview, it is different from the sequential run. Actually, the decomposition was not done properly, the solid region which corresponds to a fluid region are not in the same processor, so I believe the coupled temperature did not work, which gives a different result.
After, I tried with the "simple" decomposition method to put the solid and the surrounding fluid in the same processor. But as the solid region is smaller than the fluid region, there are still some regions where they are not connected, and thus, give bad results.
The "manual" decomposition method may solve my issues, but I don't know how to create my own "cellDecomposition" file. I tried decomposePar -cellDict to have a cellDecomposition file, but it is just a list of 0, 1, 2 and 3, I don't know how to work with it.
I would appreciate if anyone can help me.
Thanks in advance for your help !
Loïc
loic.ruan is offline   Reply With Quote
Old   September 8, 2015, 05:33
Loïc Ruan
The OpenFOAM extend 3.0 is actually not working well in parallel. So I used the extend 3.1 version to make it work.
However you still need to add the globalFaceZones option in the decomposeParDict.
Loïc
Old   September 8, 2015, 05:47
Thumbs up
Sonia_DUO is on a distinguished road
Loïc
Thanks a lot
Sonia_DUO is offline   Reply With Quote
conjugateheatfoam, coupled, parallel
Some questions about a multi region case run in parallel zfaraday OpenFOAM Running, Solving & CFD 5 February 23, 2017 11:25
Case running in serial, but Parallel run gives error atmcfd OpenFOAM Running, Solving & CFD 18 March 26, 2016 13:40
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 17:49
problem in parallel run in Workbench Mina_Shahi CFX 0 September 8, 2011 12:27
Unable to run OF in parallel on a multiple-node cluster quartzian OpenFOAM 3 November 24, 2009 14:37
