June 12, 2015, 12:54 |
Chtmultiregionfoam
Peng Liang
Rep Power: 12 |
Hello Foamers,
I am intending to simulate arc discharge in a laval nozzle, but using chtmultiregionfoam i always can't get a reseanable results , the time step always turns out to be extremly small and pressure and velocity distribution also unreasonable. Can chtSolver really simulate transsonic and supersonic problems? I see from .C File that it'a combination of bouyantFoam and HeatconductionFoam. Thanks in advance. Peng |
June 12, 2015, 14:29 |
N/A
Rep Power: 16 |
chtMultiRegionFoam is not ideally suited for trans-sonic, supersonic cases. You will need to combine sonicFoam with the multiRegion capabilities of chtMultiRegionFoam. |
September 6, 2021, 07:22 |
Joao Coelho
Rep Power: 5 |
Was anyone able to "merge" chtMultiRegionFoam with any solver for high speed flow? (rhoCentralFoam or sonicFoam).
Thanks. |
Error in thermophysical properties (chtMultiRegionFoam) | mukut | OpenFOAM Pre-Processing | 28 | November 23, 2021 06:34 |
chtMultiRegionFoam connection between solid and fluid region of heat exchanger | ahab | OpenFOAM | 1 | December 18, 2019 00:37 |
chtmultiregionFoam error | oilsok | OpenFOAM Running, Solving & CFD | 1 | June 12, 2014 11:19 |
FOAM FATAL IO ERROR for chtMultiRegionFoam | xiaoyoyo | OpenFOAM Running, Solving & CFD | 0 | May 8, 2012 16:49 |
Embed explicitSetValue in chtMultiRegionFoam | samiam1000 | OpenFOAM | 2 | April 18, 2012 05:14 |
