6-DoF Rigid Body Motion
Old   June 7, 2015, 18:58
Default 6-DoF Rigid Body Motion
Gianpaolo
jumpa72 is on a distinguished road
Hi, I'm running a simulation of a cross-flow turbine, with interDyMFoam.
I've modeled the rotor with the 6-dof rigid body motion. The simulation is running fine, but I've a problem.
The rotor is spinning aroung Z-axis.
Here is the dynamicMeshDict
sixDoFRigidBodyMotionCoeffs
    patches         (pala);
    innerDistance   1e5; // Extent of the solid-body motion region around body
    outerDistance   1.1e5; // Extent of mesh-morphing region around body
    centreOfMass    (0 0 0);
    mass            2;
    momentOfInertia (0.06 0.06 0.005);
        orientation
            1 0 0
            0 1 0
            0 0 1
    velocity        (0 0 0);
    acceleration    (0 0 0);
    angularMomentum (0 0 0);
//    torque  (0 0 666)
    report          on;
    accelerationRelaxation 0.3;
    value           uniform (0 0 0);
    constraints
        zAxis
            sixDoFRigidBodyMotionConstraint axis;
            axis          (0 0 1);
    fixedPt
        sixDoFRigidBodyMotionConstraint point;
         point    (0 0 0);
    restraints
        rotationDamper
           sixDoFRigidBodyMotionRestraint sphericalAngularDamper;
           coeff         0.1;
If the torque parameter is commented, in the mesh.update phase of the solution I've reported the 6-dof parameter update, including the angular velocity:
Restraint rotationDamper:  moment (-0 -0 23.903004)
6-DoF rigid body motion
    Centre of rotation: (0 0 0)
    Centre of mass: (0 0 0)
    Orientation: (0.70693806 -0.70727546 0 0.70727546 0.70693806 0 0 0 1)
    Linear velocity: (0 0 0)
    Angular velocity: (0 0 -239.03019)
AMI: Creating addressing and weights between 4156 source faces and 1904 target faces
AMI: Patch source sum(weights) min/max/average = 0.91803358, 1.004191, 1.0000864
AMI: Patch target sum(weights) min/max/average = 0.80581278, 1.0025247, 0.99988022
Execution time for mesh.update() = 0.58 s
smoothSolver:  Solving for alpha.water, Initial residual = 0.00032745617, Final residual = 8.2593505e-10, No Iterations 3
Phase-1 volume fraction = 0.5470669  Min(alpha1) = 0  Max(alpha1) = 1.0104109
MULES: Correcting alpha.water
Phase-1 volume fraction = 0.54706693  Min(alpha1) = -0.0002051717  Max(alpha1) = 1.0104109
smoothSolver:  Solving for Ux, Initial residual = 0.00030591356, Final residual = 6.5264777e-07, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.00011866999, Final residual = 2.7919284e-07, No Iterations 2
GAMG:  Solving for p_rgh, Initial residual = 0.00066497002, Final residual = 3.3393962e-05, No Iterations 2
time step continuity errors : sum local = 4.3662479e-08, global = -7.3058715e-10, cumulative = -0.00011849602
If the torque parameter is given, then I have no data of 6-dof parameter:
AMI: Patch source sum(weights) min/max/average = 0.65915578, 1.0035944, 0.99996507
AMI: Patch target sum(weights) min/max/average = 0.75657687, 1.0023823, 0.9998494
Execution time for mesh.update() = 0.57 s
smoothSolver:  Solving for alpha.water, Initial residual = 0.00034930917, Final residual = 1.1702469e-09, No Iterations 3
Phase-1 volume fraction = 0.54706979  Min(alpha1) = 0  Max(alpha1) = 1.0104363
My question is, is there a method to get the angular velocity of a 6-dof moving mesh?
tnx in advance
Gianpaolo
jumpa72 is offline   Reply With Quote
Old   June 8, 2015, 11:12
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi Gianpaolo,
I am guessing that it is caused by this:
In your commented block there is no closing semicolon on your "torque line". Since you have commented this line there is no problem, however if you uncomment the line, the line is not closed, so OpenFOAM will not read the next line, which specifies that it must report (to the log).
Hope this helps,
Regards,
Tom
tomf is offline   Reply With Quote
Old   June 8, 2015, 12:08
Gianpaolo
yes!
Thank you Tom, that's the problem!
Another question:
is there any detailed description of the six dof parameter?
I've found only the brief description in the .H file of six dof body motion...
tnx
Gianpaolo
Old   June 8, 2015, 12:29
Tom Fahner
I do not think there is something like that available from OpenFOAM directly, maybe you can find something by googling it, if someone has started to analyse it and make it available. I also do not know that much more about the particular library, just spotted the error since I made it myself so many times (in other applications) as well.
Regards,
Tom
Old   March 15, 2021, 09:15
Default restraints
Deutschland
vava10 is on a distinguished road
hey,
How is the restraints coefficients determined?
vava10 is offline   Reply With Quote
Old   June 2, 2021, 05:48
Himanshu
Himanshu_Shrivastava is on a distinguished road
I am running simulation for kalpan turbine with 6DOF, but the angular velocity keep on increasing.
Does that happen with your simulation?
Himanshu_Shrivastava is offline   Reply With Quote
Old   March 1, 2024, 03:38
@ss
shristi
@ss is on a distinguished road
I also want to know how the 6dof rigid body motion equation is written in openFoam directly
@ss is offline   Reply With Quote
6-dof rigid motion
trying to write a UDF for rigid body motion niteshrajput Fluent UDF and Scheme Programming 4 December 17, 2014 01:29
Rigid body motion on transient fluent mrf ghost82 EnSight 4 September 6, 2014 12:24
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Force can not converge colopolo CFX 13 October 4, 2011 23:03
rigid body motion antonello FLUENT 3 July 28, 2004 04:25
