multiple embedded AMI patches?
Old   June 4, 2015, 18:41
Default multiple embedded AMI patches?
Aljoscha Sander
k323r is on a distinguished road
Dear FOAMers,
I've been working on dynamic meshes for quite a while now, trying to implement insect wing movement. Sucess is rather limited so far. First i tried for quite a while by using dynamicTopoFvMesh; while the library is a neat little tool, mesh quality is rather a bummer. So now i'm trying to implement the movement by embedding three AMI cylinders into each other (one for each rotational axis), though that's not really working either.
So has anyone in the community ever tried such a (probably stupid) thing? The problem is that, while all the normal patches get dragged along, the slave-patches (containing the acutal wing) stay put behind (see screenshot in the appendix, the third cylinder, rotating around the z axis is not shown).
I'd be super grateful for any input or ideas on the matter. Basically what i'm trying to accomplish is the rotation of a patch around all three axis with quite large amplitudes.
Thanks in advance,
Josch
k323r is offline   Reply With Quote
Old   June 8, 2015, 01:00
Michael Page
micpage18 is on a distinguished road
Hi Josch,
What you need is to have access to immersed boundary condition. Official OpenFoam doesn't support this feature actually. However, a toolkit can be used with the Extended version.
https://openfoamwiki.net/index.php/E...mersedBoundary
Keep us informed if you try it.
Good luck
Michael Page
michael.page@simu-k.com
Simu-K inc.
www.simu-k.com
micpage18 is offline   Reply With Quote
Old   June 8, 2015, 10:01
Aljoscha Sander
Hi Michael,
thanks for your reply! i'll try it right away - at the moment i'm running into a few compilation errors, but i'll keep you posted. As to the wing motion problem: i realised, that the simplest way to model the movement is by embedding the wing model in a sphere and describe the rotation by the wings surface normal vector - so at the moment that seems to be another approach to the problem.
again, thank you for your help.
cheers,
josch
Old   June 12, 2015, 07:44
louisgag's Avatar
Louis Gagnon
louisgag is on a distinguished road
Send a message via ICQ to louisgag
Hi Josch,
If you're looking for an implementation for an embed AMI interface you could start from my code: http://www.cfd-online.com/Forums/ope...tml#post476869
You would have to adapt it to include a third level AMI and modify the normal vectors of the outer rotations because my rotations were all in the same plane.
-Louis
louisgag is offline   Reply With Quote
Old   June 12, 2015, 08:27
Aljoscha Sander
Hi Louis,
neat code! just briefly went through it, looks good thanks for the hint! i'll test it, compilation worked like a charme! I assumed by 'in the same place' your rotations all had the same centre of origin?
Old   June 12, 2015, 08:47
louisgag's Avatar
Louis Gagnon
Hi Josch,
Glad it can be useful.
I wrote in the same plane because all my rotating zones have their rotation axis normal to the x-y plane)
I think the modifications required should not be that complicated.
Let me know about it!
-Louis
ami, dynamictopofvmesh, embedded ami, insect wing, wing flapping
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 06:59
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
