InterDyMFoam Floating Object with SnappyHexMesh not solving |
#21 | |
Muhammad Hanis
Rep Power: 9 ![]() |
Currently I'm doing the simulation same like Albert case, but it got crash during running the simulation. I'm using OF 4.1 and I'm still new with OpenFoam. My project is quite similar with this paper "Investigation on a damaged ship model sinking into the water based on three dimensional SPH method" but the difference is my experiment of floating object was conducted in fully submerged and I'm using OpenFoam to validate the result. Can you help me to resolve it ? Thank you very much. Best regards, Han |
#22 |
Muhammad Hanis
Dear Jan,
I'm still awaiting for your response. Kindly appreciate if anyone can solve my issue. Thank you. Kind regards, Han |
#23 |
Sakir Karakoc
Rep Power: 0 ![]() |
Dear all,
I use openFoam. I typed these command; tutorials/multiphase/interDymFoam/Ras/FloatingObject commands. After that I loaded the parameters into Paraview, so until that phase there is no any problem even running phase. However, the floating object does not float. What is the problem you think? Thank you in advance for answers. |
hull, interdymfoam, snappyhexmesh |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 05:55 |
