MesquiteMotionSolver, prescribed motion at boundary condition depends on deltaT ? |
June 3, 2015, 04:58 |
Al_th
Rep Power: 11 |
Hi everyone,
[OF 2.3] I am encountering a weird (but maybe intentional) behaviour using mesquite as a motion solver for a dynamic mesh problem. I am simulating a cylinder where one of the base is moving in and out. At first, I was using the velocityLaplacian solver but due to some of its behaviour on cyclic patch, I had to find an alternative (basically it replaces the pointMotionU at each time steps and force cyclic patch to be cyclic even if I do not want the patches to move). Anyway, I finally decided to use the mesquiteMotionSolver that is in the dynamicTopoFvMesh library of Sandeep. I use the 2.3 port of the library, compiled it with no apparent problem, and I am able to use a prescribed motion on my boundary. Here is my dynamicMeshDict : Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object dynamicMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs ("libmesquiteMotionSolver.so"); solver mesquiteMotionSolver; mesquiteOptions { surfInterval 1; optMetric MeanRatio; objFunction LPtoP; optAlgorithm TrustRegion; tcInner { absGradL2 1e-5; cpuTime 0.05; } //- Power value for the LPtoP objective function pValue 2; power 2; //- Specify a tolerance for the surface-smoothing CG solver tolerance 1e-2; //- Specify number of CG sweeps for surface-smoothing nSweeps 2; fixedValuePatches{ cylinderBasis { type timeVaryingUniformFixedValue; value uniform (0 0 0); outOfBounds repeat; fileName "$FOAM_CASE/values"; } } } Code:
( (0 (0 0 0)) (0.001 (0 0 0)) (0.002 (0.0000104716405696524 0 0)) (0.003 (0.0000104710663911498 0 0)) (0.004 (0.0000104702051430726 0 0)) (0.005 (0.0000104690568490324 0 0)) (... (... ... ...)) (0.996000000000001 (-0.0000000553892191113015 0 0)) (0.997000000000001 (-0.0000000453188323409903 0 0)) (0.998000000000001 (-0.000000035248217367459 0 0)) (0.999000000000001 (-0.000000025177424900838 0 0)) ) I would be glad to find a solution to this because it would allow me to use dynamic deltaT instead of a fixed one. My simulation does have two different states, one where the motion of the wall is really slow, therefore the courant number drops drastically and I could save a lot of time by increasing the deltaT during those states. |
July 15, 2015, 08:03 |
Al_th
Rep Power: 11 |
Anyone please ?
February 16, 2022, 05:22 |
Pengcheng Zhang
Rep Power: 5 |
The prescribed motion of a patch is relatived to deltaT.
Because the value of pointPatchField, which you set in timeVaryingUniformFixedValue, is the relative displacement, not the absolute position of every mesh point. That is, the data you set in "values" file means the displacement vector of every mesh point at every specific time step. |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Velocity profile boundary condition | Tuca | FLOW-3D | 1 | April 23, 2013 12:02 |
No-slip condition for non-resolved boundary layer in open channel banks | Lupocci | Main CFD Forum | 1 | January 17, 2013 03:11 |
asking for Boundary condition in FLUENT | Destry | FLUENT | 0 | July 27, 2010 00:55 |
External Radiation Boundary Condition for Grid Interface | CFD XUE | FLUENT | 0 | July 9, 2010 02:53 |
