reactingParcelFoam 2D crash in parallel, works fine in serial
Old   May 28, 2015, 13:15
Default reactingParcelFoam 2D crash in parallel, works fine in serial
Ferdinand Pfender
FerdiFuchs is on a distinguished road
Hi everyone,
im solving a "simple" 2d channelflow with air and a spray with water in 2d (similar to $FOAM_TUT/lagrangian/reactingParcelFoam/verticalChannel), just in 2d.
When i try to run this case in parallel, the solver crashes at the first injection timestep with the following errormessage:
Solving 2-D cloud reactingCloud1
--> Cloud: reactingCloud1 injector: model1
Added 91 new parcels
[$HOSTNAME:31049] *** An error occurred in MPI_Recv
[$HOSTNAME:31049] *** reported by process [139954540642305,1]
[$HOSTNAME:31049] *** on communicator MPI_COMM_WORLD
[$HOSTNAME:31049] *** MPI_ERR_TRUNCATE: message truncated
[$HOSTNAME:31049] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
[$HOSTNAME:31049] ***    and potentially your MPI job)
[$HOSTNAME:31035] 2 more processes have sent help message help-mpi-errors.txt / mpi_errors_are_fatal
[$HOSTNAME:31035] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
In serial, it runs fine without any error. If i change number of $WM_NCOMPPROCS, sometimes the solver stucks instead of crashing. htop shows then a lot of red cpu usage (kernel threads).
i found something in the net; someone had the same error here, solved it by disable functionObjects and cloudFunctions. Not in my case...
method for decomposing is also irrelevant, i checked simple and scotch.
Maybe this thread is also better placed in OpenFOAM bugs? if someone could confirm this, i will also open an issue in OF-2.3.x-bugtracking.
Tomorrow ill check it in OF-2.4.x and in FE-3.1.
If somebody knows what to do, every help is appreciated. This case is some kind of urgent for me.
Thank you very much!
FerdiFuchs is offline   Reply With Quote
Old   June 11, 2015, 07:31
oswald is on a distinguished road
I'm having a similar problem with a lagrangian tracking solver in parallel, based on icoUncoupledKinematicParcelFoam. It works at first, but after some time it crashes with the same error message as in your case.
[ran:7367] *** An error occurred in MPI_Waitall
[ran:7367] *** on communicator MPI_COMM_WORLD
[ran:7367] *** MPI_ERR_TRUNCATE: message truncated
[ran:7367] *** MPI_ERRORS_ARE_FATAL: your MPI job will now abort
mpirun has exited due to process rank 0 with PID 7367 on
node ran exiting improperly. There are two reasons this could occur:
1. this process did not call "init" before exiting, but others in
the job did. This can cause a job to hang indefinitely while it waits
for all processes to call "init". By rule, if one process calls "init",
then ALL processes must call "init" prior to termination.
2. this process called "init", but exited without calling "finalize".
By rule, all processes that call "init" MUST call "finalize" prior to
exiting or it will be considered an "abnormal termination"
This may have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
And, also as in your case, sometimes it just gets stuck somewhere without crashing. I tried to narrow down the step where it gets stuck and it seems to be that in kinematicCloud.evolve() in kinematicCloud.C it is stuck at getting the trackingData
template<class CloudType>
void Foam::KinematicCloud<CloudType>::evolve()
    Info << "start kinematicCloud.evolve" << endl;
    if (solution_.canEvolve())
        Info << "solution can evolve, getting track data" << endl;
        typename parcelType::template
            TrackingData<KinematicCloud<CloudType> > td(*this);
        Info << "start solving" << endl;
        solve(td);
When the solver is stuck, my program's last output is "solution can evolve, getting track data". So it seems to be some error there.
When changing the commsType from nonBlocking to blocking in $WM_PROJECT_DIR/etc/controlDict, the error is:
[0]
[0]
[0] --> FOAM FATAL IO ERROR:
[0] error in IOstream "IOstream" for operation operator>>(Istream&, List<T>&) : reading first token
[0]
[0] file: IOstream at line 0.
[0]
[0]     From function IOstream::fatalCheck(const char*) const
[0]     in file db/IOstreams/IOstreams/IOstream.C at line 114.
[0]
FOAM parallel run exiting
[0]
oswald is offline   Reply With Quote
Old   August 4, 2015, 11:32
Default reproduced
clockworker is on a distinguished road
Hi there!
I ran into the same error message in a case similar to
$FOAM_TUT/lagrangian/reactingParcelFoam/verticalChannel/
On the tutorial case i was able to reproduce the described behavior
with the following commands:
#!/bin/sh
cd ${0%/*} || exit 1    # run from this directory
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
# create mesh
runApplication blockMesh
cp -r 0.org 0
# initialise with potentialFoam solution
runApplication potentialFoam
rm -f 0/phi
# run the solver
runApplication pyFoamDecompose.py . 4
runApplication pyFoamPlotRunner.py mpirun -np 4 reactingParcelFoam -parallel
# ----------------------------------------------------------------- end-of-file
The calculation hangs at
Courant Number mean: 1.705107874 max: 4.895575368
deltaT = 0.0004761904762
Time = 0.0109524
Solving 3-D cloud reactingCloud1
with htop showing CPU usage of ~ 100 % on all cores.
If i deactivate
dispersionModel none;//stochasticDispersionRAS;
I can reproduce the error message in the OP:
[$Hostname:15844] *** An error occurred in MPI_Recv
[$Hostname:15844] *** on communicator MPI_COMM_WORLD
[$Hostname:15844] *** MPI_ERR_TRUNCATE: message truncated
[$Hostname:15844] *** MPI_ERRORS_ARE_FATAL: your MPI job will now abort
I use Ubuntu 14.04.3 LTS with openfoam240. Can anyone else confirm this behaviour or even provide a solution?
Thank you very much for your time.
Last edited by clockworker; August 5, 2015 at 03:19. Reason: Politeness, Anonymitiy. Sorry first time posting.
clockworker is offline   Reply With Quote
Old   August 7, 2015, 04:03
Hi there,
I think I stumbled upon a solution
I changed the reactingCloud1Properties from
massTotal       8;
duration        10000;
to
massTotal       0.0008;
duration        1;
and the calculation continued without the error messages
Hope this helps someone.
Old   August 10, 2015, 10:18
Ferdinand Pfender
mh this does not really help.
what you changed is the timeframe of the injection and the mass which is injected in this time.
The Injection starts at SOI for the defined timeframe.
If you change these values, you will definetly get results you dont want to have.
Greets,
Ferdi
Old   August 10, 2015, 19:19
Default 3rd try
Hi Ferdi,
I was under the impression that you can maintain a constant mass flow rate if you change massTotal proportional to the duration according to this
HTML Code:
http://www.dhcae-tools.com/images/dhcaeLTSThermoParcelSolver.pdf
as long as duration is longer as endTime. I stand corrected if this is not the case.
Nonetheless, I was not able to reproduce the described behavior at home on 2 cores anymore. Meaning the error messages appear no matter what I do with massTotal or duration.
What I tried now was changing the injectionModel from patchInjection to coneNozzleInjection like this:
injectionModels
            model1
        type            coneNozzleInjection;
        SOI             0.01;
        massTotal       8;
        parcelBasisType mass;
        injectionMethod disc;
      	flowType 	constantVelocity;
      	UMag 		40;
        outerDiameter   6.5e-3;
        innerDiameter   0;
        duration        10000;
        position        ( 12.5e-3 -230e-3 0 );
        direction       ( 1 0 0 );
        parcelsPerSecond 1e5;
        flowRateProfile constant 1;
        Cd              constant 0.9;
        thetaInner      constant 0.0;
        thetaOuter      constant 1.0;
        sizeDistribution
                type        general;
                generalDistribution
                    distribution
                        (10e-06      0.0025)
                        (15e-06      0.0528)
                        (20e-06      0.2795)
                        (25e-06      1.0918)
                        (30e-06      2.3988)
                        (35e-06      4.4227)
                        (40e-06      6.3888)
                        (45e-06      8.6721)
                        (50e-06      10.3153)
                        (55e-06      11.6259)
                        (60e-06      12.0030)
                        (65e-06      10.4175)
                        (70e-06      10.8427)
                        (75e-06      8.0016)
                        (80e-06      6.1333)
                        (85e-06      3.8827)
                        (90e-06      3.4688)
And now the error messages disappear I don't know if coneNozzleInjection is applicable in 2D but perhaps that does provide a workaround. Or perhaps ManualInjection can be an alternative. I have to try this at my work case. It is also 2D.
Thanks Ferdi for taking the time.
Greetings
clockworker
Poisson eq w setReference works serial diverges in parallel tehache OpenFOAM Running, Solving & CFD 5 August 29, 2012 10:41
serial run fine, but parallel run diverged phsieh2005 OpenFOAM Running, Solving & CFD 2 October 6, 2009 09:33
Parallel run diverges, serial does not SammyB OpenFOAM Running, Solving & CFD 1 May 10, 2009 04:28
interpret works fine but compile doesn't Jan Balemans FLUENT 0 March 14, 2008 10:41
Serial run OK parallel one fails r2d2 OpenFOAM Running, Solving & CFD 2 November 16, 2005 13:44
