May 22, 2015, 16:22 |
How can I use Foam-Extend Cuda Solvers?
Paul Handy
Rep Power: 12 |
I just followed this document, which entails details the installation of openfoam-extend with cuda solvers. However, with all my searching, I haven't found anything that shows how to use the newly available gpu acceleration.
On cpu, I previously used `mpirun` to parallelize my cases. What should I use to push simulations to my GPU? Alternatively, am I using the wrong tool for my goal? I've noticed that "RapidCFD" is another CUDA implementation of openfoam, but I don't know how to use GPU with it either. |
May 26, 2015, 03:51 |
Rep Power: 11 |
I think that the answer is here: http://www.cfd-online.com/Forums/ope...end-3-0-a.html
Did you have a problems with compilation of cudaSolvers ? I had a problems with cusp... So I can't test the solvers... |
April 13, 2019, 04:50 |
TheresaJRosenberg
You can search it online in google search, if still you need help.
cuda, foam-extend, gpu, mpirun |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
