May 20, 2015, 17:48 |
decomposePar won't break case for 8 cores
#1 | |||
António Soares
Rep Power: 11 |
Hi everyone, I have an i7 processor with 8 cores (I can view them in Ubuntu System Manager) but when I configure the decomposeParDict file to distribute it over 8 cores I get an error message that says it' an uneven distribution of cores. Right now I have it running as follows:
Does anyone have any idea of what I might be doing wrong? Thanks. |
May 20, 2015, 18:06 |
#2 | |
Jace
Rep Power: 16 |
n (4 4 1) gives your 16 cores, not 8...(you basically tell OpenFOAM to decompose into 16 regions when you only have 8 cores in your disposal.) you need to divide in as (2 2 2), or (2 4 1), etc... |
May 20, 2015, 22:04 |
António Soares
Rep Power: 11 |
Thanks for the reply.
I guess I didn't understand the decomposition process. I thought each digit meant the number of cores assigned to each direction (x y z) independently, I didn't really understand how the decomposition was accomplished by creating the mesh regions. I'll try this again once the current simulation stops. Once again, my thanks. |
decomposepar, openmpi, parallel, parallel compressible, sonicfoam |
Pressure instabilities with interDyMFoam for the floatingObject case | nbadano | OpenFOAM Running, Solving & CFD | 15 | October 15, 2021 07:35 |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 16:13 |
How to delay releasing the water column in dam break case? | Pirlu | OpenFOAM Running, Solving & CFD | 3 | June 5, 2014 00:04 |
Error reading new case | montag dp | FLUENT | 5 | September 15, 2011 07:00 |
Turbulent Flat Plate Validation Case | Jonas Larsson | Main CFD Forum | 0 | April 2, 2004 11:25 |
