defining solid and fluid in chtMultiregionFoam
Old   May 19, 2015, 07:09
Default defining solid and fluid in chtMultiregionFoam
rafath
R_21 is on a distinguished road
Hi Foamers,
I am trying to modify chtMultiregionfoam to my use and while in the main code it is divided into solid and fluid regions. I understand we must define solid and fluid regions in the case directory but according to this tutorial
http://www.slideshare.net/ARPITSINGH...regiontutorial
i have to define a file under .setSet defining the blocks for solid and fluid regions. But, while looking into the case directory of tutorial for chtmultiregionfoam, i couldn't find any files under the format.
Can someone please tell me how to define the two regions. Also i am trying to mesh using "gmsh". Should I use blockmesh instead ??
regards,
rafath
R_21 is offline   Reply With Quote
Old   May 23, 2015, 03:01
Default Figured it out
rafath
My bad , figured it out
Old   July 1, 2015, 11:54
Default Fluid and Solid Regions in chtMRF
Bruce Clarke
BClarke352 is on a distinguished road
I'm trying to model a fluid flow in a pipe through a steel block, where one face of the steel block is being heated. However, I'm having trouble defining my initial conditions to get a realistic result - for example the velocity in the pipe is defined as 1 m per s at the beginning but I'm not sure how to define my inletOutlet bc correctly, and I want to temperature throughout the domain to be calculated to an output file but for some reason OpenFOAM doesn't like the calculated boundary condtion.
I'm really stuck on this, so any help would be greatly appreciated.
Thanks!
BClarke352 is offline   Reply With Quote
chtMultiRegionFoam connection between solid and fluid region of heat exchanger ahab OpenFOAM 1 December 18, 2019 01:37
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
chtMultiRegionFoam, fixed convection coefficient between fluid and solid romain.h OpenFOAM Running, Solving & CFD 0 September 19, 2012 15:43
solid to fluid heattransfer with chtMultiRegionFoam nakor OpenFOAM 11 March 21, 2011 09:28
Defining Solid Zones Not working elmcmaster FLUENT 3 May 22, 2009 08:14
