Varying times during MPI parallel runs
Old   May 18, 2015, 12:31
Default Varying times during MPI parallel runs
Deep Ray
d_ray is on a distinguished road
I have written a C++ code for a finite volume solver to simulate 2D compressible flows on unstructured meshes, and parallelised my code using MPI (openMPI 1.8.1). I partition the initial mesh into N parts (which is equal to the number of processors being used) using gmsh-Metis. In the solver, there is a function that calculates the numerical flux across each local face in the various partitions. This function takes the the left/right values and reconstructed states (evaluated prior to the function call) as input, and returns the corresponding flux. During this function call, there is no inter-processor communication, since all the input data is available locally. I use MPI_Wtime to find the time taken for each such function call. With 6 processors (Intel® Core™ i7 (3770)), I get the following results:
Processor 1: 1406599932 calls in 127.467 minutes
Processor 2: 1478383662 calls in 18.5758 minutes
Processor 3: 1422943146 calls in 65.3507 minutes
Processor 4: 1439105772 calls in 40.379 minutes
Processor 5: 1451746932 calls in 23.9294 minutes
Processor 6: 1467187206 calls in 32.5326 minutes
I am really surprised with the timings, especially those from processors 1 and 2. Processor 2 makes almost 80 million more calls than processor 1 but takes 1/7 the time taken by processor 1. I re-iterate that there is no inter-processor communication taking place in this function. Could the following cause this large a variation in time?
1. Conditional-if loops inside the function
2. The magnitude of the values of input variables. For instance, if a majority of the values in for a processor are close to 0.
If not these, could there be any other reason behind this disparity?
d_ray is offline   Reply With Quote
c++, finite volume method, mpi parallel, timings
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
How to setup a simple OpenFOAM cluster? TommiPLaiho OpenFOAM Installation 3 October 27, 2013 16:15
Problems about distributed parallel runs vkrastev OpenFOAM Running, Solving & CFD 10 November 11, 2012 10:22
Error with parallel computing: MPI therandomestname FLUENT 1 June 28, 2012 05:12
Error using LaunderGibsonRSTM on SGI ALTIX 4700 jaswi OpenFOAM 2 April 29, 2008 11:54
