dynamic mesh fails in parallel executation
Old   May 7, 2015, 10:58
Default dynamic mesh fails in parallel executation
Hao Chen
hchen is on a distinguished road
Dear Foamers:
I use dynamic mesh to simulate flow around oscillating cylinders in foam extend 3.1. The dynamic mesh simply update the displacement of the cylinder and call the fvMotionSolver. It works fine in serial case, but for parallel execution, the mesh is moving in a strange way in between the processor boundary. I attached the figures below. The location where the unphysical moving mesh occurs is just in between the domains for processors. I am not sure this is due to the problem of my custom dynamic mesh class (although I do not think so) or other OpenFoam problems?
Best regards
Hao Chen
hchen is offline   Reply With Quote
Old   May 7, 2015, 14:14
Hao Chen
Hi again,,,
For some other cases, I found that the mesh in the processor boundary does not move at all. In the figure below, I impose a rigid body motion on the cylinder and also the mesh near the cylinder. The rest is moving with fvDisplacementLaplacian. However, the point in the boundary does not move at all. Any suggestions and comments are welcome.
Old   October 22, 2015, 06:01
YS
Ya_Squall2010 is on a distinguished road
I am having the same problem in running interDyMFoam using multiple CPUs. It even crashes when you run the accompanied floatingObject tutorial case in parallel. Have you identified the source of this problem? Thanks.
Ya_Squall2010 is offline   Reply With Quote
Old   January 27, 2016, 08:35
hayder
hayder is on a distinguished road
I am having the same problem in running fluent with dynamic mesh using parallel mode . Have you identified the source of this problem?
If Yes could you please send me some tips. Thanks in advance.
hayder is offline   Reply With Quote
Old   March 15, 2016, 01:06
YS
I'd like to know if anyone else is having this problem? Or is there a solution to it?
Old   March 16, 2016, 02:30
Hrvoje Jasak
Please use tet FEM automatic mesh motion solvers and all will be well.
Hrvoje
Hrvoje Jasak
Old   March 16, 2016, 04:47
Hao Chen
Yes I think FEM is much robuster than FVM for foam extend versions. Otherwise if you still want to use FVM dynamic mesh, you'd better change to openfoam official versions.
Best
Hao
Old   March 16, 2016, 22:50
YS
The reason why I tried to switch to fvMotionSolver is that I'd like to compare the BiCGStab to GAMG, as sometimes the former is struggling in 3D cases, even 100+ subiterations are not enough for it to reach convergence.
Old   March 31, 2017, 04:37
chengan.wang
wangchengan2003 is on a distinguished road
Send a message via Skype™ to wangchengan2003
Dear Jasak
I try to make parallization for the dynamic mesh problem by using the solver pimpleDyMFoam. The orginal case 'movingCone' works well under parallization process. But if "
dynamicFvMesh dynamicMotionSolverFvMesh;
motionSolverLibs ( "libfvMotionSolvers.so" );
solver velocityComponentLaplacian;
velocityComponentLaplacianCoeffs
component x;
diffusivity directional ( 1 200 0 );
" in the file 'dynamicMeshDict' is simplely changed as "
dynamicFvMesh movingConeTopoFvMesh;
movingConeTopoFvMeshCoeffs
motionVelAmplitude (1.5 0.0 0.0);
motionVelPeriod 0.003;
leftEdge 0.0;
leftObstacleEdge 0.0;
rightObstacleEdge 0.0;
right
minThickness 3e-5;
maxThickness 6e-5;
left
minThickness 3e-5;
maxThickness 5e-5;
", which means the mesh has topological changes, the parallization doesn't work any more. (it works fine with single processor).Of2.4.0 is used.
If you could give me some suggestions?
Best regards.
wangchengan2003 is offline   Reply With Quote
Old   March 31, 2017, 04:44
chengan.wang
Dear Jasak,
component x;
leftEdge 0.0;
right
minThickness 3e-5;
maxThickness 6e-5;
left
minThickness 3e-5;
maxThickness 5e-5;
, which means the mesh has topological changes, the parallization doesn't work any more. (it works fine with single processor). And Of2.4.0 is used.
I think the problem is similar. If you could give me some suggestions?
Best regards,
Old   September 26, 2017, 13:22
Default Problem solved in FE 4.0
  #11
alia's Avatar
Ali Aghaei
alia is on a distinguished road
Originally Posted by hchen View Post
Hi again,,,
This bug has been fixed in foam-extend 4.0
Cheers.
alia is offline   Reply With Quote
Old   June 14, 2018, 01:30
jiahui_93 is on a distinguished road
Originally Posted by wangchengan2003 View Post
Dear Jasak,
component x;
leftEdge 0.0;
right
minThickness 3e-5;
maxThickness 6e-5;
left
minThickness 3e-5;
maxThickness 5e-5;
Best regards,
Hi, i am facing exactly the same problem as yours. Had you found the solution? If yes, would u mind n could you please share with me? Thanks a lot
Sincerely,
Jia Hui
jiahui_93 is offline   Reply With Quote
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 09:27
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[Other] dynamic Mesh with angular velocity not parallel to x axis donQi OpenFOAM Meshing & Mesh Conversion 5 October 3, 2014 00:19
InterDyMFoam dynamic meshing in parallel fails under nonquiescent conditions adona058 OpenFOAM Bugs 7 November 18, 2008 15:58
