pisoFoam: symbol lookup error:
Old   May 7, 2015, 08:01
Default pisoFoam: symbol lookup error:
Zhiyi Li
comingdaytime is on a distinguished road
Hallo, Everyone,
Today when I am running the pisoFoam today, I have this Error:
Case : /home/itvzl/OpenFOAM/gen_new/generators08052013/channel_st
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
Reading field U
pisoFoam: symbol lookup error: /home/itvzl/OpenFOAM/itvzl-2.1.x/platforms/linux64GccDPOpt/lib/libsyntheticTurbulencePoliMi.so: undefined symbol: _ZN4Foam20turbulentLengthScale3NewINS_12fvPatchFie ldINS_6VectorIdEEEEEEPS0_RKNS_10dictionaryERKNS_4T imeERKT_RKNS_4wordE
This libsyntheticTurbulencePoliMi.so library is not the openfoam selfcontained library. And I also have the library file libsyntheticTurbulencePoliMi.so in the user folder. But there is symbol look up error. Does anybody know what happened and how could I solve this problem?
Thank you very much
Best Regards
Litchy
comingdaytime is offline   Reply With Quote
Old   May 8, 2015, 08:17
Zhiyi Li
And I tried today with another case, the same library needed in the controlDict. Also the same solver, it is still the same problem. Symbol look up error.Is this because of the library's problem? For example, not compiling it correctly?
Old   June 3, 2015, 14:37
Sim81 is on a distinguished road
I am having the same problem, no idea
Sim81 is offline   Reply With Quote
Old   June 4, 2015, 09:08
Zhiyi Li
And the same look up error? Do you think it's because the problem of the library or the way we compile it ?
Old   June 4, 2015, 10:25
In my case I have found what the problem was. In the file make/files I did not include the correct *.C file. That means that the library is created but the *.C files are not linked correctly. Therefore, information is missing for the solver to run. May be in your case the file that contains
is not linkedcorrectly.
I hope this helps
Old   June 5, 2015, 06:13
Zhiyi Li
I hope this helps
Hey,
Thank you first for your hint.
And I check my file in the Make folder:
syntheticTurbulence=syntheticTurbulence
$(syntheticTurbulence)/syntheticTurbulence/syntheticTurbulence.C
$(syntheticTurbulence)/syntheticTurbulence/generateSyntheticFluctuations.C
$(syntheticTurbulence)/turbulentLengthScale/uniform/uniformLengthScale.C
$(syntheticTurbulence)/turbulentLengthScale/generic/genericLengthScale.C
$(syntheticTurbulence)/turbulentLengthScale/kw/kwLengthScale.C
$(syntheticTurbulence)/turbulentLengthScale/turbulentLengthScale/turbulentLengthScale.C
$(syntheticTurbulence)/syntheticTurbulenceInletFvPatchField/syntheticTurbulenceInletFvPatchField.C
LIB = $(FOAM_USER_LIBBIN)/libsyntheticTurbulencePoliMi
It seems to be fine.
But there is one thing, every *.C file should be accompanied by a *.H file with the same name, right? I just found one *.C file with a *.H file in a different name in the 'syntheticTurbulence' folder. I don't know if this is the problem. I'll try on it.
Best Regards
Litchy
Old   July 2, 2015, 06:38
Default PisoFoam - Error report
Gizela
Gizazu is on a distinguished road
Hi. I finally got the simulation working but i have a litlle problems with definition of delta T and courant number which sometimes send back an error during the process. Could you help me with this doubt? What possibly I´m doing wrong?
Another question is that I´m doing a 3D simulation but i can only see Ux and Uz during the calculation. Is that normal?
Please, somebody help me!!!
Regards
Gizazu is offline   Reply With Quote
Old   July 2, 2015, 06:54
Zhiyi Li
Maybe your courant number is larger than one in some fine mesh region? I could see Ux, Uy, Uz, in my simulation. I'm also a beginner of this. Hope others could help you.
Good luck.
library, openfoam 2.1.x, symbol
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 08:11
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
using METIS functions in fortran dokeun Main CFD Forum 7 January 29, 2013 05:06
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
