Initialisation with results from another case |
May 6, 2015, 05:08 |
Jean-Pierre
Rep Power: 12 |
Dear all,
Is there any utlity to use the results of a converged case as an initialisation to another one knowing that the U field is not the same between both cases? I hope it helps the second case converge. I have searched and tried with mapFields but I haven't succed. Thanks for your help |
convergence, initialisation, u field |
MRFSimpleFoam wind turbine case continuity error | ysh1227 | OpenFOAM Running, Solving & CFD | 1 | August 16, 2016 09:25 |
Comparing Air numerical results with water experimental results | cristian2009es | Main CFD Forum | 1 | July 2, 2014 18:11 |
Centrifugal Fan Case Study Results Required using CFX | kambireddy | CFX | 0 | October 8, 2010 05:46 |
Changing the grid on the same set-up | Katya | FLUENT | 7 | October 8, 2009 16:31 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
