May 2, 2015, 06:09 |
Constant multiplied by a Laplacian
Anonymous
Hello Everyone,
I am trying to solve this equation using OpenFoam: dP/dt=z/(∅*P*C ) ∇(P*k/(μ*z) ∇P) ....eq.1 However, it seems there no command to discritize a scalar multiplied by a laplacian. So I decomposed the equation to the following (d(uv)=udv+vdu): dP/dt=∇(k/(∅*μ*C) ∇P)-P*k/(μ*z) ∇(z/(∅*P*C))∇P.....eq2 I wrote the second equation as: volScalarField A = K/PHI/MU/C; fvSclaraMatrix pEqn ( fvm::ddt(p) - fvm::laplacian(A,p) +(fvc::grad(p)&fvc::grad(zeta/(PHI*p*C)))*K/(MU*zeta) == fvOptions(p) ); So my solver runs, and I can get a solution, however it is a wrong solution. More often than not, I need to have large relaxation numbers to even get a solution. I am new to OpenFoam, so I thought I might ask for help for a way to apply the initial equation 1 without the need to decompose it into equation 2 (It is the second term on the rhs of equation 2 that is causing trouble, so I am not sure about its discritization). Is there a way to multiply a scalar by a laplacian in equation number 1? Thank you very much, and please bear with me if I made stupid remarks or comments that showed lack of understanding, as I am new. Thanks. |
fluid flow but temperature raises from nowhere? | mxcfd | STAR-CCM+ | 5 | September 16, 2014 06:46 |
Some questions about Laplacian with nonorthogonal correction | koderer | OpenFOAM | 3 | December 12, 2012 18:30 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 19:44 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 07:25 |
Really big problems when creating own materials da | Jop | FLUENT | 0 | June 28, 2007 12:15 |
