Potential bug in turbulentTemperatureCoupledBaffleMixed |
May 1, 2015, 00:38 |
N/A
Rep Power: 16 |
I am using the turbulentTemperatureCoupledBaffleMixed boundary condition with chtMultiRegionFoam and OpenFOAM v 2.3.1. I am running the solution until a steady-state condition is reached to verify with steady-state solutions. I have two blocks in contact; one block contains a constant volumetric heat generation (first image, block aligned with x=0 has a source of 1e6 w/m^3). In the first case there is no contact resistance and the results match with analytical calculations (second image). At the x = 2*L (with L being the length of one block), I have a constant wall temperature. The other boundaries effectively make this a 1D problem. However, now I apply a contact resistance: Code:
box_1_to_box_2 { type compressible::turbulentTemperatureCoupledBaffleMixed; value uniform 310.0; Tnbr T; kappa solidThermo; kappaName none; thicknessLayers (1e-5); kappaLayers (1e-2); } I am just starting to diagnose why this is happening, but I won't be able to get to it in the near term. I just wanted to put this out there. Last edited by kamakura117; May 1, 2015 at 00:42. Reason: Added version number. |
May 1, 2015, 00:49 |
N/A
Rep Power: 16 |
How to calculate electrical potential with UDS? | seagullor | FLUENT | 3 | August 25, 2024 21:39 |
Bug in Workbench CFX | Pierre1 | CFX | 6 | August 2, 2017 01:18 |
Problem modelling potential equations with addtional variables | pmtgt | CFX | 4 | October 3, 2013 09:20 |
Potential Flow | Swapnil | CFX | 5 | February 26, 2003 08:33 |
Question on 3D potential flow | Adrin Gharakhani | Main CFD Forum | 13 | June 21, 1999 06:18 |
