pimpleFoam Simulation aroud a cylinder does not converges
Old   April 28, 2015, 09:27
Default pimpleFoam Simulation aroud a cylinder does not converges
ASo
ASo is on a distinguished road
Hi all,
I'm trying to learn how to use pimpleFoam. In order to do this I'm trying to simulate the flow around a cylinder, I'm doing this at high Reynolds (7.10^6) because I will have to make simulations at this Reynolds. I read this about pimpleFoam :
http://www.cfd-online.com/Forums/blo...hm-part-i.html
http://www.cfd-online.com/Forums/blo...m-part-ii.html
At all of the timesteps, the simulation did not converged after 50 pimple iterations (nOuterCorrectors = 50).
It seems to be an easy simulation (flow around a cylinder). Can you tell me what is wrong in my simulation ..
Thanks for answers !!
An extract of the log.pimpleFoam file (first part of the file and a part of the last timestep):
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.3.0
Exec   : pimpleFoam -parallel
Date   : Apr 27 2015
Time   : 15:48:10
Host   : "nemo1"
PID    : 12414
Case   : /data/cylindre_insta4
nProcs : 32
Slaves :
31
"nemo1.12415"
"nemo1.12416"
"nemo1.12417"
"nemo1.12418"
"nemo1.12419"
"nemo1.12420"
"nemo1.12421"
"nemo1.12422"
"nemo1.12423"
"nemo1.12424"
"nemo1.12425"
"nemo1.12426"
"nemo1.12427"
"nemo1.12428"
"nemo1.12429"
"nemo1.12430"
"nemo1.12431"
"nemo1.12432"
"nemo1.12433"
"nemo1.12434"
"nemo1.12435"
"nemo1.12436"
"nemo1.12437"
"nemo1.12438"
"nemo1.12439"
"nemo1.12440"
"nemo1.12441"
"nemo1.12442"
"nemo1.12443"
"nemo1.12444"
"nemo1.12445"
Pstream initialized with:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model kOmegaSST
kOmegaSSTCoeffs
    alphaK1         0.85034;
    alphaK2         1;
    alphaOmega1     0.5;
    alphaOmega2     0.85616;
    gamma1          0.5532;
    gamma2          0.4403;
    beta1           0.075;
    beta2           0.0828;
    betaStar        0.09;
    a1              0.31;
    b1              1;
    c1              10;
    F3              false;
No finite volume options present
PIMPLE: max iterations = 50
    field U    : relTol 0, tolerance 1e-05
    field p    : relTol 0, tolerance 0.0005
Starting time loop
Courant Number mean: 1.27401 max: 9.54351
Time = 5
PIMPLE: iteration 1
smoothSolver:  Solving for Ux, Initial residual = 0.0059193, Final residual = 4.07869e-05, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.00996702, Final residual = 8.40309e-05, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.00529798, Final residual = 5.20881e-05, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.536424, Final residual = 0.00275772, No Iterations 2
time step continuity errors : sum local = 2.97493e-05, global = 5.66073e-06, cumulative = 0.00585719
PIMPLE: iteration 2
PIMPLE: iteration 47
smoothSolver:  Solving for Ux, Initial residual = 0.000179332, Final residual = 1.82244e-06, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.000553898, Final residual = 4.81264e-06, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.000286557, Final residual = 2.57935e-06, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0244919, Final residual = 0.000130336, No Iterations 3
time step continuity errors : sum local = 1.74618e-06, global = 4.28654e-07, cumulative = 0.0058756
PIMPLE: iteration 48
smoothSolver:  Solving for Ux, Initial residual = 0.000177181, Final residual = 1.74186e-06, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.000562329, Final residual = 4.91611e-06, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.000281855, Final residual = 2.38418e-06, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.024675, Final residual = 0.000131996, No Iterations 3
time step continuity errors : sum local = 1.7573e-06, global = -4.33255e-07, cumulative = 0.00587516
PIMPLE: iteration 49
smoothSolver:  Solving for Ux, Initial residual = 0.000178031, Final residual = 1.77695e-06, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.000554551, Final residual = 4.84694e-06, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.000284683, Final residual = 2.50979e-06, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0244865, Final residual = 0.000131006, No Iterations 3
time step continuity errors : sum local = 1.75527e-06, global = 4.31808e-07, cumulative = 0.0058756
PIMPLE: iteration 50
smoothSolver:  Solving for Ux, Initial residual = 0.00131143, Final residual = 7.81589e-06, No Iterations 5
smoothSolver:  Solving for Uy, Initial residual = 0.00361828, Final residual = 8.30476e-06, No Iterations 7
smoothSolver:  Solving for Uz, Initial residual = 0.0022754, Final residual = 6.55988e-06, No Iterations 7
GAMG:  Solving for p, Initial residual = 0.507878, Final residual = 8.37436e-08, No Iterations 14
time step continuity errors : sum local = 2.59953e-09, global = -2.61579e-10, cumulative = 0.0058756
smoothSolver:  Solving for omega, Initial residual = 0.00988738, Final residual = 5.73628e-06, No Iterations 6
smoothSolver:  Solving for k, Initial residual = 0.00649944, Final residual = 6.7763e-06, No Iterations 8
PIMPLE: not converged within 50 iterations
ExecutionTime = 20304.7 s  ClockTime = 20311 s
End
Finalising parallel run
fvSolution file :
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver           GAMG;
        tolerance        1e-7;
        relTol           0.01;
        smoother         DICGaussSeidel;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator     faceAreaPair;
        mergeLevels      1;
    pFinal
        $p;
        relTol          0;
    "(U|k|omega)"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-05;
        relTol          0.1;
    "(U|k|omega)Final"
        $U;
        relTol          0;
PIMPLE
    nNonOrthogonalCorrectors 0;
    nCorrectors         1;
    nOuterCorrectors    50;
    residualControl
        U
                tolerance  1e-5;
                relTol     0;
        p
                tolerance  5e-4;
                relTol     0;
relaxationFactors
    fields
        p       0.3;
        pFinal   1;
    equations
        "U|k|omega"           0.3;
        "(U|k|omega)Final"     1;
potentialFlow
    nNonOrthogonalCorrectors 10;
pRefCell        0;
    pRefValue       0;
    residualControl
        p               1e-5;
        U               1e-5;
       k        1e-5;
    omega 1e-5;
fvSchemes file :
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss linearUpwind grad(U);
    div(phi,k)      bounded Gauss upwind;
//    div(phi,epsilon) bounded Gauss upwind;
    div(phi,omega)      bounded Gauss upwind;
//    div(R)          Gauss linear;
//    div(phi,nuTilda) bounded Gauss upwind;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
//    laplacian(nuEff,U) Gauss linear corrected;
//    laplacian(rAUf,p)  Gauss linear corrected;
//    laplacian(DkEff,k) Gauss linear corrected;
//    laplacian(DepsilonEff,epsilon) Gauss linear corrected;
//    laplacian(DREff,R) Gauss linear corrected;
//    laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
ASo is offline   Reply With Quote
Old   April 29, 2015, 05:19
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
You can probably use higher relaxation factors in your inner iterations:
relaxationFactors
    fields
        p       0.8;
        pFinal   1;
    equations
        "U|k|omega"           0.8;
You would have to play around with these on how high you can go.
There may however be something wrong with your boundary conditions or mesh as well.
tomf is offline   Reply With Quote
Old   April 30, 2015, 06:05
ASo
Thanks for the answer !!
As you thought with higher relaxation factors it does not converge.
Does anyone have an idea about something that could be bad with my mesh or other ??
Old   April 30, 2015, 06:14
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
As usual, please post:
1. checkMesh output
2. Your initial and boundary conditions (or just an archive of 0 folder)
3. And finally geometry of your problem (or a screenshot of the mesh), as several times on this forum people thought they are simulating flow around cylinder and yet they were not.
alexeym is offline   Reply With Quote
Old   April 30, 2015, 06:35
ASo
Thanks for answer :
Here are the information you ask me.
There is :
  • The log.checkMesh code
  • An archive of 0 folder
  • Three screenshots of the mesh from paraview :
  • -3dmesh is a view oh the internal mesh
  • -meshcut is a slice of the internal mesh in the "normal to the cylinder axis and central plane".
  • -meshcut_cylinder is the same slice with the mesh of the patch "cylinder" represented as a surface.
If you need more information tell me !!
The log.checkMesh file :
Build  : 2.3.0
Exec   : checkMesh
Date   : Apr 29 2015
Time   : 22:23:59
Host   : "nemo1"
PID    : 27356
nProcs : 1
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    faces:            697280
    internal faces:   679552
    cells:            226560
    faces per cell:   6.07712
    boundary patches: 6
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     218400
    prisms:        1536
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     6624
    Breakdown of polyhedra by number of faces:
        faces   number of cells
            6   2112
            9   2688
           12   1824
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
                   Patch    Faces   Points                  Surface topology
            frontAndBack     7936     8352  ok (non-closed singly connected)
                  outlet      576      625  ok (non-closed singly connected)
                   inlet      576      625  ok (non-closed singly connected)
               lowerWall     2016     2125  ok (non-closed singly connected)
               upperWall     2016     2125  ok (non-closed singly connected)
                cylindre     4608     4656  ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-6 -3 -3) (15 3 3)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (-4.92725e-19 2.71585e-16 -1.4847e-16) OK.
    Max cell openness = 3.3278e-16 OK.
    Max aspect ratio = 2.56187 OK.
    Minimum face area = 0.00149621. Maximum face area = 0.0635283.  Face area magnitudes OK.
    Min volume = 9.46489e-05. Max volume = 0.0158862.  Total volume = 751.325.  Cell volumes OK.
    Mesh non-orthogonality Max: 26.2533 average: 4.97247
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.341876 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
Old   April 30, 2015, 06:40
Tom Fahner
Change the boundary condition for pressure on your inlet to zeroGradient. I generally do not use the freestream boundary types, but I guess they could be used. I do believe there is also a freestreampressure boundary condition, that one may also work.
Regards,
Tom
Old   April 30, 2015, 08:06
Alexey Matveichev
Agree with tomf about BC for pressure. You impose inlet velocity and no pressure gradient along the channel. It is a little bit strange, no?
Mesh seems to be OK (hope inlet is really inlet and outlet is really outlet), though usually people make it denser not only around cylinder but also near the center of the channel.
Old   May 4, 2015, 11:15
ASo
Thanks for answers :
I'm confused about pressure boundary conditions:
If I want to simulate my the cylinder in a total free flow (not in a channel), should I use zeroGradient for all of the boundaries (even for inlet and oulet) ??
Old   May 6, 2015, 05:20
Tom Fahner
Well your setup inevitably results in a channel-like flow. If you want (almost) freestream conditions I would suggest this setup:
Increase the height of your domain and prescribe your freestream conditions on the top and bottom boundaries as if they were inlets: fixedValue for velocity and turbulence, zeroGradient for pressure.
For the outlet set a fixedValue pressure (0) and zeroGradient for all other variables. Otherwise look at the setup for the case:
$FOAM_TUTORIALS/incompressible/simpleFoam/airFoil2D
That one uses a setup with freestream boundary conditions.
Regards,
Tom
Old   May 6, 2015, 08:33
ASo
Ok thanks for the details about boundary conditions.
I'e seen the airfoilD tutorial but it is a 2D simulation, I would like to do this in 3D but I don't know what boundary condition to use for the frontAndBack patches.
I will try the first solution you gave me.
Old   May 6, 2015, 08:46
Tom Fahner
Yes it is 2D, but it shows the use of the freestream boundary conditions.
For 3D I would use slip on the frontAndBack patches for velocity, calculated for nut and zeroGradient for all others. If you have a finite length of your cylinder and want to include end effects you could make these freestream as well, but I think you should decide that for yourself after thinking about what it is exactly that you want to simulate.
Old   May 7, 2015, 09:43
ASo
One more thanks for answer
Regards,
Tom
This worked : after few time steps it converges after few Pimple iterations (8 for example depends of the other parameters).
I'm still trying to set freestream boundary conditions when I'm using those parameters I've got an error about field p.
I join the 0 folder.
Here is an extract of the log.pimpleFoam with the error message :
[16]
[16]
[16] --> FOAM FATAL IO ERROR:
[16] Unable to set reference cell for field p
    Please supply either pRefCell or pRefPoint
[16]
[16]
[16] file: IOstream.PIMPLE from line 0 to line 0.
[16]
[16]     From function void Foam::setRefCell
    const volScalarField&,
    const dictionary&,
    label& scalar&,
    bool
[16]     in file cfdTools/general/findRefCell/findRefCell.C at line 125.
[16]
FOAM parallel run exiting
[16]
Old   May 7, 2015, 10:33
Tom Fahner
This means you need something like this in your system/fvSolution (the bold font part) but than in the PIMPLE subDict. Instead of pRefCell you can also use pRefPoint (search the forum for explanations). I took this from the airfoil2D tutorial.
SIMPLE
    pRefCell        0;
    pRefValue       0;
    residualControl
        p               1e-5;
        U               1e-5;
        nuTilda         1e-5;
Please note that if you have vortex shedding you may see an effect of an alternating pressure in the entire domain, which probably messes up any animations, but should not effect your forces.
Simulation of convective heat loss from cylinder buidu Main CFD Forum 9 April 28, 2015 08:11
2d simulation on cylinder with grooves madcyclop2 Main CFD Forum 1 January 25, 2014 05:26
simulation of cylinder vibrating ali moghimifar FLUENT 2 March 2, 2012 14:18
3D LES simulation of a circular cylinder fpz Main CFD Forum 3 June 20, 2005 20:50
Simulation of the Flow past a circular cylinder using STAR-CD M. S. GUEROUACHE Main CFD Forum 0 October 1, 1998 11:51
