Changing to CGS units
Old   April 23, 2015, 12:17
Default Changing to CGS units
riccardo maione
riccardomaione is on a distinguished road
Hello all,
I am trying to run openfoam with CGS units. All my initial conditions are in cgs, so pressure is 10^6 g/cm/s^2 (dimensions [1 -1 -2 0 ...]) and velocity in cm/s (dimensions [0 1 -1 0...]) , to solve a flow in a fluidised bed with air, in order to do so I added in the controlDict
DimensionedConstants
unitSet CGS; // SI; // USCS; //
CGSCoeffs
universal
c c [ 0 1 -1 0 0 0 0 ] 2.99792e+10; // speed of light in vacuum (cm/s)
G G [ -1 3 -2 0 0 0 0 ] 6.67429e-8; // gravitational constant (cm^3/(gs^2))
h h [ 1 2 -1 0 0 0 0 ] 6.62607e-27; // Planck's constant (erg.s)
R R [1 2 -2 -1 -1 0 0 ] 8.314e7; //universal gas constant (erg/mol*K)
electromagnetic
e e [ 0 0 1 0 0 1 0 ] 4.803204e-10; // elementary charge (statcoulomb)
atomic
me me [ 1 0 0 0 0 0 0 ] 9.10938e-28; // electron mass (g)
mp mp [ 1 0 0 0 0 0 0 ] 1.67262e-24; // proton mass (g)
physicoChemical
mu mu [ 1 0 0 0 0 0 0 ] 1.66054e-24; // atomic mass unit (g)
k k [ 1 2 -2 -1 0 0 0 ] 1.38065e-16; // Boltzman constant (erg/K)
standard
//- Standard pressure [bar]
Pstd Pstd [ 1 -1 -2 0 0 0 0 ] 1000000; // 1 bar (barye)
//- Standard temperature [degK]
Tstd Tstd [ 0 0 0 1 0 0 0 ] 298.15; // should be same as in SI unit system
however when trying to run the case the density is like 10, when it should be 1e-3. what is the matter? someone has already done this passage and knows how to help?
every help is greatly appriciated,
Riccardo
riccardomaione is offline   Reply With Quote
Old   April 24, 2015, 11:28
riccardo maione
noone knows how to pass from SI to another unit system?
Old   April 24, 2015, 11:36
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
And how do you set initial conditions in your simulation?
alexeym is offline   Reply With Quote
Old   April 24, 2015, 13:05
riccardo maione
I used the input in CGS, so pressure is 1e6 barye and velocity inlet is 5 cm/s. Unfortunately I need this type of input because I have to couple it with a DEM program and I have been playing quite a lot in order to understand what isn't right
funny thing is that if I use the CGS constants and I set the SI input output (so the initial conditions are in SI) with the control dictionary, adding this to the controlDict:
DimensionSets
unitSet SI; // USCS
SICoeffs
// Basic units
kg kg [ 1 0 0 0 0 0 0 ] 1.0;
m m [ 0 1 0 0 0 0 0 ] 1.0;
s s [ 0 0 1 0 0 0 0 ] 1.0;
K K [ 0 0 0 1 0 0 0 ] 1.0;
mol mol [ 0 0 0 0 1 0 0 ] 1.0;
A A [ 0 0 0 0 0 1 0 ] 1.0;
Cd Cd [ 0 0 0 0 0 0 1 ] 1.0;
// Derived units
Hz Hz [ s^-1 ] 1.0;
N N [ kg m s^-2 ] 1.0;
Pa Pa [ N m^-2 ] 1.0;
J J [ N m ] 1.0;
W W [ J s^-1 ] 1.0;
// Some non-symbolic ones
area area [m^2] 1.0;
volume volume [m^3] 1.0;
density density [ kg m^-3 ] 1.0;
acceleration acceleration [ m s^-2 ] 1.0;
kinematicPressure kinematicPressure [ Pa density^-1 ] 1.0;
// Scaled units. Only allowed in dimensionedType (dimensionedScalar,
// dimensionedVector etc.) and UniformDimensionedField, not
// in DimensionedField or GeometricField
cm cm [ m ] 1e-2;
mm mm [ m ] 1e-3;
km km [ m ] 1e3;
// Set of units used for printing. Can be any basic or derived
// but not scaled (only supported for dimensionedScalar, etc)
writeUnits (kg m s K mol A Cd);
density is ok and 1 kg/m^3. However in order to understand what is going on, I used a string to output the universal gas constant. In this case the constant is ok with the correct value in CGS, but its dimensionality is in Kg and m!
I am a little frustrated , somebody knows what's going on?
thank you for your reply
Riccardo
Thermophysical Property Units johanz OpenFOAM Pre-Processing 2 December 16, 2018 11:08
[PyFoam] Problems with the new PyFoam release zfaraday OpenFOAM Community Contributions 13 December 9, 2014 19:58
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 08:18
changing units in gambit Brendan FLUENT 2 August 13, 2012 10:12
Changing units in AVL Fire zaer AVL FIRE 2 July 18, 2012 01:27
