backwardFacingStep: unable to get the correct reattachment length
Old   April 21, 2015, 19:31
Default backwardFacingStep: unable to get the correct reattachment length
anonym
snowgetu is on a distinguished road
Dear Foamers!
I am trying to do a a backward facing step simulation according to this webpage: http://turbmodels.larc.nasa.gov/backstep_val.html
I have specified the boundary conditions to reach a reynolds number of 36000 but I never get close to the reattachment length (max. 5.5). Can anyone tell me what is wrong with my simulation? (I think the boundary layer is wrong but I'm a bit confused about the Reynolds number as well..)
I am sending my simulation files with the post.
Thank you in advance!
snowgetu is offline   Reply With Quote
Old   April 22, 2015, 03:03
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
1. Your mesh differs from the one on NASA's site.
2. You use incompressible solver, while:
As discussed elsewhere on this site, note that all cases are compressible flow verification and validation cases. Although many are at low Mach numbers such that the flow is "essentially" incompressible, if you run with an incompressible code your results will not exactly correspond with the compressible code results given here.
(http://turbmodels.larc.nasa.gov/noteonrunning.html)
3. How did you calculate inlet value for k and epsilon?
alexeym is offline   Reply With Quote
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 08:22
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Reattachment Point in separated flow Eric FLUENT 2 July 25, 2007 04:38
the reattachment length of rearward facing step Tom,L. Main CFD Forum 4 December 14, 2002 05:24
Fluent, reattachment length Adrian Main CFD Forum 4 March 25, 1999 20:07
