Problem: volume fraction of gas bubble with twoPhaseEulerFoam
Old   April 20, 2015, 04:06
Default Problem: volume fraction of gas bubble with twoPhaseEulerFoam
morteza javid
morteza1991 is on a distinguished road
Hi every body,
I'm trying to simulate gas bubble in openFoam with twoPhaseEulerFoam. Flow is simulated correctly but volume fraction of gas bubble are wrong since it is not 1 as I expected.
I think my problem is caused by phase properties document but I don't know what it is.I'm kind of new user of openFoam. please tell me what should I do ?!
morteza1991 is offline   Reply With Quote
Old   April 20, 2015, 07:33
Vishal
vishal3 is on a distinguished road
Hi Morteza
May I know the details of your case?? What exactly do you want??
Which OF version are you using???
vishal3 is offline   Reply With Quote
Old   April 20, 2015, 08:23
morteza javid
Thank you for your reply, I try to simulate a two phase flow consists of Water and N2 gas in rectangular channel. As you know,N2 gas is undissolved gas, so alpha in gas bubbles must be 1 but alpha according to result, is around 0.5.
Also I'm using openfoam 2.3.1
Old   April 20, 2015, 14:49
Mihai Pruna
mihaipruna is on a distinguished road
I assume this solver uses the VOF method, so the interface will not be sharp. Maybe relative to the size of your bubbles , it gets smeared resulting in values less than 1.
Try with a more refined grid.
Also, I saw this tutorial , might help:
http://www.tfd.chalmers.se/~hani/kur...PhaseEuler.pdf
Mihai Pruna's Bio
mihaipruna is offline   Reply With Quote
Old   April 21, 2015, 17:42
hester is on a distinguished road
twoPhaseEulerFoam assumes two interpenetrating fluids. Therefore you get the wrong volume fraction values.
Have a look at interFoam. It is using VOF and should be able to model the phase fractions better.
http://www.tfd.chalmers.se/~hani/kur...Hemida_VOF.pdf
Regards,
hester
hester is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
Problem: bubble column with twoPhaseEulerFoam hester OpenFOAM Running, Solving & CFD 6 January 22, 2016 13:25
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
