Different momentum equation in different versions of settlingFoam
Old   April 15, 2015, 14:09
Default Different momentum equation in different versions of settlingFoam
Shenan
Shenan is on a distinguished road
The momentum equation for settlingFoam is different in OpenFOAM 2.2.1 and FOAM-extend 3.1. The term
-(fvc::grad(U) & fvc::grad(muEff))
is missing in FE 3.1.
In OF 2.2, the momentum equation is:
fvVectorMatrix UEqn
    fvm::ddt(rho, U)
  + fvm::div(phi, U)
  + fvc::div
        (Alpha/(scalar(1.001) - Alpha))*(sqr(rhoc)/rho)*Vdj*Vdj,
        "div(phiVdj,Vdj)"
  - fvm::laplacian(muEff, U, "laplacian(muEff,U)")
  - (fvc::grad(U) & fvc::grad(muEff))
In FE 3.1, the momentum equation is:
fvVectorMatrix UEqn
    fvm::ddt(rho, U)
  + fvm::div(phi, U)
  + fvc::div
        "div(phiVdj,Vdj)"
  - fvm::laplacian(mu, U, "laplacian(muEff,U)")
The equations are based on the mixture momentum equation in Dan Brennan's thesis (2001, p86). Are both equations correct?
In OF 2.3.1, settlingFoam has been replaced with driftFluxFoam. Its momentum equation is:
fvVectorMatrix UEqn
    fvm::ddt(rho, U)
  + fvm::div(rhoPhi, U)
  + fvc::div(UdmModel.tauDm())
  + turbulence->divDevRhoReff(U)
    fvOptions(rho, U)
divDevRhoReff is defined in kEpsilon.C as:
tmp<fvVectorMatrix> kEpsilon::divDevRhoReff
    const volScalarField& rho,
    volVectorField& U
) const
    volScalarField muEff("muEff", rho*nuEff());
    return
      - fvm::laplacian(muEff, U)
      - fvc::div(muEff*dev(T(fvc::grad(U))))
Hence, in OF 2.* there appears to be a connection between:
and
If so, please can you tell me the relationship between
and
Thank you.
Shenan is offline   Reply With Quote
drift flux model, settlingfoam
solving the momentum equation in UEqn. callahance OpenFOAM 2 October 18, 2012 10:38
Coefficients discretized momentum equation michujo Main CFD Forum 4 June 20, 2012 02:33
Question on the discretization of momentum equation in icoFoam MPJ OpenFOAM 3 October 4, 2011 10:44
What is the Boussinesq Term in Momentum Equation CFDtoy Main CFD Forum 0 August 11, 2008 10:56
momentum equation cfp CFX 0 July 8, 2002 05:48
