Large eddy simulation for flow around cylinder
Old   April 15, 2015, 08:15
Default Large eddy simulation for flow around cylinder
ashish kulkarni
ash_kul999 is on a distinguished road
Hello all,
I want to perform Large Eddy Simulation for flow around 2D circular cylinder.Fluid medium is water and the diameter of cylinder is 0.1m. I am using PISOFoam solver. I had tried the simulation many a times by changing various parameters in the solver. I could visualize the flow in the paraFoam but when it comes to validation part, the values of coefficient of drag,lift and moment are wrong (in the order of 1e10).I am not able to fix this problem. Can anyone suggest me what could be the reasons behind this? If possible please send me benchmark test case setup file.
thanks,
Ashish
ash_kul999 is offline   Reply With Quote
Old   April 15, 2015, 10:01
rama13's Avatar
Damiano Natali
rama13 is on a distinguished road
Hi Ashish,
please find in attachment two different cases of flow around cylinder at Re=2*1e6, one using RANS and one with LES, both with pisoFoam.
Results are obviously not the same -they have runned on the same mesh-, but at least they share the same order of magnitude!
Hope this helps,
Damiano
LES.zip
RAS.zip
Damiano Natali Eng Phd | R&D and FEA Engineer
________________________________________
Cressall | Optimum Resistor Solutions
Evington Valley Road, Leicester, Leicestershire, LE5 5LZ, UK.
NERs | Load Banks | Marine & Offshore | DBRs | Renewables
rama13 is offline   Reply With Quote
Old   April 15, 2015, 14:11
ashish kulkarni
Thanks a lot sir!!! I will compare with this set up and do the correction. I will post my further queries and results here.
Old   April 17, 2015, 18:06
ashish kulkarni
Sir,
I am having trouble with swak4foam while installing. what is the exact role of it in this simulation? can we perform LES without swak4foam?
Old   April 18, 2015, 05:02
rama13's Avatar
Damiano Natali
Sure, you have to comment out some functions in the system/controlDict
Bests,
Damiano
Old   April 18, 2015, 05:47
ashish kulkarni
Sir,
I have installed swak4foam. The test case is running fine.But unlike my previous simulations I am not getting forceCoeffs.dat file in the postprocessing folder. How to get the vlaues of Cd,Cl and Cm i the results?
coefficient drag, coefficient of lift, coefficient of moment, flow around a cylinder, large eddy simulation
Mean flow field in Large Eddy Simulation Servantes STAR-CCM+ 1 September 11, 2014 18:32
Unstructured Large Eddy Simulation Solver problems samurai_01 Main CFD Forum 10 December 30, 2013 04:17
Large eddy simulation jii1 FLUENT 0 May 11, 2010 15:23
Large eddy simulation on unstructured grid vanchisen Main CFD Forum 4 July 6, 2009 23:44
Large Eddy simulation Andreas Hauser Main CFD Forum 1 May 20, 2000 21:33
