Simulation of bubble under oscillation
Old   April 13, 2015, 18:07
Default Simulation of bubble under oscillation
Arsalan
arsalan.dryi is on a distinguished road
Dear foamers,
I'm doing a 2D simulation of bubble rising under nonlinear oscillation of the container with interDyMFoam,for oscillation motion of the container i used the solid body motion of a mesh and function of oscillatingLinearMotion in dynamicFvMesh with the function of x=Asin(wt),but the results of the simulation are wrong,bubble motion is very faster than experimental and other simulation results,and at the initial time steps(t=8e-05) the bubble is moving to the left side of simulation domain and going out of the domain!while the bubble motion should be very slower and at t=0.04s the direction of bubble velocity should be change to the right side!
Any help will be appreciated!
arsalan.dryi is offline   Reply With Quote
bubble, interdymfoam, oscillation
bubble diameter definition in multi phase flow boiling simulation FLUENT Abishek FLUENT 13 July 1, 2019 13:12
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
Help required for CFD simulation of Trayed Bubble Column using Fluent art705 Main CFD Forum 0 July 15, 2009 05:04
Air Bubble simulation Raj CFX 1 October 6, 2008 23:53
phase filed simulation of a bubble qunwuhe@hotmail.com Main CFD Forum 0 June 5, 2007 23:56
