Mesh Motion is not consistent
Like Tree2Likes
Old   June 20, 2015, 19:30
Pruthvi
pruthvi1991 is on a distinguished road
The solver runs properly for amplitude of 20 degrees. I tried for 30 degrees and its crashing.
I use moveDynamicMesh to see if the mesh quality is OK in all the time steps. Then I proceed to use the pimpleDyMFoam solver to calculate the flowfield.
Thanks,
Pruthvi.
pruthvi1991 is offline   Reply With Quote
Old   June 21, 2015, 07:15
Hassan Kassem
hk318i is on a distinguished road
If the mesh quality is fine using moveDyMesh. if should works with the fluid solver as well.
If you are using fixed time step try to used adjustable time step based on Co. number.
hk318i is offline   Reply With Quote
Old   December 11, 2020, 08:53
Default airfoil is not moving
  #23
Ram
guptaram is on a distinguished road
Originally Posted by hk318i View Post
Here is the link
https://github.com/HIKassem/twoDOscillatingDisplacement
it is my first time to use github, so it could be not working or I messed up something.
Bw,
Hassan
Hi hk318i (Hassan Kassem),
I am facing small issue while running your code, can you help me to resolve it?
I am performing pitching and heaving motion of airfoil. Your code compiled without any error. However, while running simulation I faced one error as " there is no new entries for fvMotionSolver", so I replaced libfvMotionsolver.so into libmy2DOF.so. After that, simulation ran but my boundary is not moving, it behaves like a static airfoil motion.
I don't know where I am doing wrong. Please correct me or guide me.
Thank you so much
Best Regards,
Ram
guptaram is offline   Reply With Quote
flapping wing simulation, pimpledymfoam, sixdofrigidbodymotion
Update of the variables after dynamic mesh motion. gtg258f OpenFOAM Programming & Development 9 January 18, 2014 11:08
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
Dynamic moving mesh Pei-Ying Hsieh (Hsieh) OpenFOAM Running, Solving & CFD 64 June 7, 2012 11:04
