simpleFoam 3D case: crashes after 7 cycles
Like Tree1Likes
Old   April 11, 2015, 15:42
Default simpleFoam 3D case: crashes after 7 cycles
alvaro
alvariten is on a distinguished road
I am beginner in the field of CFD and OpenFOAM.
I need some help or advice with my case. Basically I have used the PitzDaily default case of OpenFOAM tutorials but with a new 3D geometry instead of 2D and new boundary values of pressure and velocity.
These are the values of p, U, k and epsilon:
dimensions      [0 2 -2 0 0 0 0];
 internalField   uniform 0;
 boundaryField
     walls
         type            zeroGradient;
     inlet
         type            fixedValue;
         value           uniform 200;
     outlet
         type            fixedValue;
         value           uniform 0;
dimensions      [0 1 -1 0 0 0 0];
 internalField   uniform (0 0 0);
 boundaryField
     walls
         type            fixedValue;
         value           uniform (0 0 0);
     inlet
         type            fixedValue;
     outlet
         type            zeroGradient;
 internalField   uniform 0.375;
 boundaryField
     walls
         type            kqRWallFunction;
         value           uniform 0.375;
     inlet
         type            fixedValue;
     outlet
         type            zeroGradient;
dimensions      [0 2 -3 0 0 0 0];
 internalField   uniform 14.855;
 boundaryField
     walls
         type            epsilonWallFunction;
         value           uniform 14.855;
     inlet
         type            fixedValue;
     outlet
         type            zeroGradient;
When I run the case, it stop at seventh cycle of calculation and show the follow error:
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam"
#9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Any help or advice is gratefully.
by the by I would like upload a jpg file of residual values from my desktop but I don't know how do it.
alvariten is offline   Reply With Quote
Old   April 11, 2015, 18:15
Troy Snyder
tas38 is on a distinguished road
Originally Posted by alvariten View Post
 boundaryField
     walls
         type            zeroGradient;
     inlet
         type            fixedValue;
         value           uniform 200;
     outlet
         type            fixedValue;
         value           uniform 0;
 boundaryField
     walls
         type            fixedValue;
     inlet
         type            fixedValue;
     outlet
         type            zeroGradient;
 boundaryField
     walls
     inlet
         type            fixedValue;
     outlet
         type            zeroGradient;
 boundaryField
     walls
     inlet
         type            fixedValue;
     outlet
         type            zeroGradient;
Please post the entire log file. If it runs for seven "cycles" as you say, the issue is
either divergence or there is an error writing and output file. Based on what you posted
it appears that the latter is more likely.
Also, please post your solver settings files if they differ from the pitzDaily tutorial.
tas38 is offline   Reply With Quote
Old   April 12, 2015, 07:06
alvaro
Here is the output log file:
alvaro@AlvaroPC:~/OpenFOAM/run/pitzDaily$ simpleFoam
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.3.0-f5222ca19ce6
Exec   : simpleFoam
Date   : Apr 12 2015
Time   : 11:44:53
Host   : "AlvaroPC"
PID    : 2859
Case   : /home/alvaro/OpenFOAM/run/pitzDaily
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    sigmaEps        1.3;
No finite volume options present
SIMPLE: convergence criteria
    field p     tolerance 0.01
    field U     tolerance 0.001
    field "(k|epsilon|omega)"     tolerance 0.001
Starting time loop
streamLine streamLines:
    automatic track length specified through number of sub cycles : 5
Time = 1
smoothSolver:  Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.0384349, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.095593, No Iterations 1
time step continuity errors : sum local = 52.102, global = -0.56931, cumulative = -0.56931
smoothSolver:  Solving for epsilon, Initial residual = 0.988297, Final residual = 0.000247036, No Iterations 1
bounding epsilon, min: -3.70276 max: 188967 average: 41.0059
smoothSolver:  Solving for k, Initial residual = 1, Final residual = 0.0800895, No Iterations 1
ExecutionTime = 0.32 s  ClockTime = 0 s
Time = 2
smoothSolver:  Solving for Ux, Initial residual = 0.645571, Final residual = 0.0636477, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.443996, Final residual = 0.00986204, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.691369, Final residual = 0.0653874, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.999027, Final residual = 0.0763541, No Iterations 4
time step continuity errors : sum local = 31.7509, global = 1.89734, cumulative = 1.32803
smoothSolver:  Solving for epsilon, Initial residual = 0.695385, Final residual = 2.08712e-05, No Iterations 1
smoothSolver:  Solving for k, Initial residual = 0.919585, Final residual = 0.0823362, No Iterations 2
ExecutionTime = 0.45 s  ClockTime = 0 s
Time = 3
smoothSolver:  Solving for Ux, Initial residual = 0.440654, Final residual = 0.0427516, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.560425, Final residual = 0.0419665, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.410988, Final residual = 0.0349522, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.642045, Final residual = 0.063517, No Iterations 2
time step continuity errors : sum local = 38.5966, global = -9.32056, cumulative = -7.99253
smoothSolver:  Solving for epsilon, Initial residual = 0.224899, Final residual = 3.99216e-06, No Iterations 1
bounding epsilon, min: -13464.6 max: 7.90228e+06 average: 9149.1
smoothSolver:  Solving for k, Initial residual = 0.474471, Final residual = 0.045027, No Iterations 2
ExecutionTime = 0.57 s  ClockTime = 0 s
Time = 4
smoothSolver:  Solving for Ux, Initial residual = 0.773657, Final residual = 0.050837, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.600411, Final residual = 0.0464153, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.733712, Final residual = 0.0562857, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.840831, Final residual = 0.0582094, No Iterations 1
time step continuity errors : sum local = 321.621, global = 81.3235, cumulative = 73.3309
smoothSolver:  Solving for epsilon, Initial residual = 0.740998, Final residual = 9.77163e-05, No Iterations 1
bounding epsilon, min: -984.549 max: 8.36834e+08 average: 362259
smoothSolver:  Solving for k, Initial residual = 0.949549, Final residual = 0.0942416, No Iterations 2
ExecutionTime = 0.69 s  ClockTime = 1 s
Time = 5
smoothSolver:  Solving for Ux, Initial residual = 0.732108, Final residual = 0.0686708, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.476365, Final residual = 0.0449628, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.446049, Final residual = 0.0407226, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.840493, Final residual = 0.0792588, No Iterations 1
time step continuity errors : sum local = 234.221, global = 66.9484, cumulative = 140.279
smoothSolver:  Solving for epsilon, Initial residual = 0.228923, Final residual = 1.06908e-06, No Iterations 1
bounding epsilon, min: -3.43861e+07 max: 6.90822e+10 average: 4.3941e+07
smoothSolver:  Solving for k, Initial residual = 0.452072, Final residual = 0.0196315, No Iterations 2
bounding k, min: -485.765 max: 3.29082e+06 average: 8562.43
ExecutionTime = 0.81 s  ClockTime = 1 s
Time = 6
smoothSolver:  Solving for Ux, Initial residual = 0.278225, Final residual = 0.0234514, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.240453, Final residual = 0.0144066, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.359935, Final residual = 0.0329614, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.916368, Final residual = 0.0709018, No Iterations 1
time step continuity errors : sum local = 6564.03, global = 184.483, cumulative = 324.762
smoothSolver:  Solving for epsilon, Initial residual = 0.013258, Final residual = 0.000666225, No Iterations 1
bounding epsilon, min: -2.72697e+08 max: 1.56504e+13 average: 4.78779e+09
smoothSolver:  Solving for k, Initial residual = 0.4201, Final residual = 0.0274674, No Iterations 1
bounding k, min: -40309.9 max: 1.33333e+09 average: 716884
ExecutionTime = 0.93 s  ClockTime = 1 s
Time = 7
smoothSolver:  Solving for Ux, Initial residual = 0.0337342, Final residual = 0.00201148, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.0468805, Final residual = 0.00289706, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.0158243, Final residual = 0.000456582, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.110785, Final residual = 0.00775269, No Iterations 2
time step continuity errors : sum local = 2.54362e+14, global = 4.21581e+11, cumulative = 4.21581e+11
smoothSolver:  Solving for epsilon, Initial residual = 1, Final residual = 0.0349246, No Iterations 3
smoothSolver:  Solving for k, Initial residual = 1, Final residual = 0.0851641, No Iterations 1
ExecutionTime = 1.05 s  ClockTime = 1 s
Time = 8
smoothSolver:  Solving for Ux, Initial residual = 0.515451, Final residual = 0.0207056, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.722785, Final residual = 0.0488147, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.818181, Final residual = 0.0520304, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.999684, Final residual = 0.0983319, No Iterations 5
time step continuity errors : sum local = 2.51385e+14, global = -2.99544e+12, cumulative = -2.57385e+12
smoothSolver:  Solving for epsilon, Initial residual = 0.0130558, Final residual = 8.86302e-16, No Iterations 1
bounding epsilon, min: -1.21842e+35 max: 4.92931e+40 average: 8.18944e+36
smoothSolver:  Solving for k, Initial residual = 0.5328, Final residual = 0.0426716, No Iterations 1
bounding k, min: -4.2741e+20 max: 5.74832e+36 average: 1.05138e+33
ExecutionTime = 1.2 s  ClockTime = 1 s
Time = 9
smoothSolver:  Solving for Ux, Initial residual = 0.0524346, Final residual = 0.00248475, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.22741, Final residual = 0.0195766, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.010153, Final residual = 0.000734547, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.00514794, Final residual = 0.000331134, No Iterations 2
time step continuity errors : sum local = 3.5522e+33, global = -1.27833e+31, cumulative = -1.27833e+31
smoothSolver:  Solving for epsilon, Initial residual = 1, Final residual = 0.0524548, No Iterations 29
smoothSolver:  Solving for k, Initial residual = 3.38676e-07, Final residual = 3.38676e-07, No Iterations 0
ExecutionTime = 1.35 s  ClockTime = 1 s
Time = 10
smoothSolver:  Solving for Ux, Initial residual = 0.646186, Final residual = 0.0522116, No Iterations 40
smoothSolver:  Solving for Uy, Initial residual = 0.56795, Final residual = 0.0301241, No Iterations 41
smoothSolver:  Solving for Uz, Initial residual = 0.529712, Final residual = 0.0287035, No Iterations 38
Floating point exception (core dumped)
And when you say solver settings files you mean ControlDict file, isn't it? Here is, but I didn't modified anything
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     simpleFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         1000;
deltaT          1;
writeControl    timeStep;
writeInterval   50;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
functions
    streamLines
        type            streamLine;
        // Where to load it from (if not already in solver)
        functionObjectLibs ("libfieldFunctionObjects.so");
        // Output every
        outputControl   outputTime;
        // outputInterval 10;
        setFormat       vtk; //gnuplot;//xmgr;//raw;//jplot;//csv;//ensight;
        // Velocity field to use for tracking.
        UName U;
        // Tracked forwards (+U) or backwards (-U)
        trackForward    true;
        // Names of fields to sample. Should contain above velocity field!
        fields (p k U);
        // Steps particles can travel before being removed
        lifeTime        10000;
        // Number of steps per cell (estimate). Set to 1 to disable subcycling.
        nSubCycle 5;
        // Cloud name to use
        cloudName       particleTracks;
        // Seeding method. See the sampleSets in sampleDict.
        seedSampleSet   uniform;  //cloud;//triSurfaceMeshPointSet;
        uniformCoeffs
            type        uniform;
            axis        x;  //distance;
            start       (-0.0205 0.001  0.00001);
            end         (-0.0205 0.0251 0.00001);
            nPoints     10;
Old   April 12, 2015, 14:10
Troy Snyder
Your solution is diverging.
I would suggest running checkMesh to look for mesh issues.
Also, I don't believe you can specify static pressure on both the inlet
and the outlet. I would change the inlet to total pressure.
Old   April 12, 2015, 15:41
alvaro
Referred to the mesh, not seen nothing unusual, except some non-orthogonal faces:
alvaro@AlvaroPC:~/OpenFOAM/run/pitzDaily2$ checkMesh
Exec   : checkMesh
Date   : Apr 12 2015
Time   : 20:11:08
Host   : "AlvaroPC"
PID    : 3402
Case   : /home/alvaro/OpenFOAM/run/pitzDaily2
nProcs : 1
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    faces:            47633
    internal faces:   39075
    cells:            21677
    faces per cell:   4
    boundary patches: 3
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     0
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    21677
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    walls               8313     4219     ok (non-closed singly connected)
    inlet               84       84       ok (non-closed singly connected)
    outlet              161      101      ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-1.66857 -0.201602 -1.67331) (2.51658 2.87607 1.67331)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (-1.95172e-16 1.45104e-16 -1.42852e-16) OK.
    Max cell openness = 1.73452e-15 OK.
    Max aspect ratio = 348.834 OK.
    Minimum face area = 2.90131e-08. Maximum face area = 0.0227372.  Face area magnitudes OK.
    Min volume = 2.83827e-11. Max volume = 0.00110686.  Total volume = 2.07994.  Cell volumes OK.
    Mesh non-orthogonality Max: 89.4051 average: 22.6028
   *Number of severely non-orthogonal (> 70 degrees) faces: 57.
    Non-orthogonality check OK.
  <<Writing 57 non-orthogonal faces to set nonOrthoFaces
    Face pyramids OK.
    Max skewness = 1.82439 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
And about the initial condition for pressure, how I change the condition to total pressure?
The case that I am trying to solver is a simulation of a 3D nozzle that inject diesel fuel to cylinder. The velocity is unknown, but at the entry and exit is depreciated. All that is known is the inlet and outlet pressure. The real values are 350 bar at inlet and 1 bar at outlet. How would you set the BC's for this case?
Thanks.
Old   April 12, 2015, 17:34
Troy Snyder
Here is an example for setting a totalPressure boundary (in p file):
 injInlet
        type            totalPressure;
        U               U;
        gamma           1.0;
        p0              uniform 111.111;
alvariten likes this.
Old   April 13, 2015, 08:02
alvaro
I tried everything you advised me, but the problem still appearing. Even so, thank you for answers and advice me. Now I am going to try make a new mesh completly structured, without non-orthogonal faces. I'll let you know if it works.
Regards.
Old   May 29, 2015, 09:53
KateEisenhower is on a distinguished road
Regards.
Hello Alvaro,
did you try with a new mesh? Did it work?
Best regards,
Kate
KateEisenhower is offline   Reply With Quote
Old   May 30, 2015, 06:52
alvaro
Hello Alvaro,
Hi Kate,
I tried it with a new mesh better quality, but still doesn't work.. and I don't know why
Now I'm working with cavitatingFoam tutorial "throttle" and the same mesh and the same condition. For now the results look good for a pressure driven flow and the cavitation phenomena.
Regards
Old   May 30, 2015, 07:06
Hi Kate,
Regards
Hi Alvaro,
did your new mesh pass all the tests from checkMesh? Another topic, I am not familiar with your type of BCs (pressure assigned at inlet AND outlet). I would look at this again. Also, I would recommend intitializing your case with turbulence switched off.
Regarding your work with the "throttle" settings. You said it looks good. Congratulations! Can you give us a bit more information on this? Does it converge, is your problem solved then?
Best regards,
Kate
P.S.: When tas38 asked about the solver settings, I think he meant the fvSolution file in the system directory.
Old   June 2, 2015, 06:03
alvaro
Hi Alvaro,
Best regards,
Kate
Hi Kate,
Sorry for my late reply.
Yes, the new mesh pass checkMesh without problem (it's a very simple geometry of a nozzle made with blockMesh)
Regarding the pressure and velocity condition:
0/p
dimensions      [1 -1 -2 0 0];
internalField   uniform 1e5;
boundaryField
    frontback
        type            empty;
    inlet
        type            totalPressure;
        U               U;
        phi             phiv;
        rho             rho;
        psi             none;
        gamma           1;
        p0              uniform 150e5;
    outlet
        type            fixedValue;
        value           uniform 1e5;
    nozzleWall
        type            zeroGradient;
    fixedWall
        type            zeroGradient;
0/U
    frontback
        type            empty;
    inlet
        type            pressureInletOutletVelocity;
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
    nozzleWall
        type            fixedValue;
    fixedWall
        type            fixedValue;
There is a simple tutorial TJuntion where you can see this kind of BC's.
About the cavitating problem, I still have problem with convergence. The case crash a few minutes to start. The residuals look fine, the only strange thing I see is highlighted in black below.
DILUPBiCG:  Solving for rho, Initial residual = 3.65416e-05, Final residual = 4.73255e-11, No Iterations 1
max-min rho: 72391.2 -6.84908
max-min gamma: 1 0
DILUPBiCG:  Solving for Ux, Initial residual = 0.00712085, Final residual = 1.85145e-11, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.00714144, Final residual = 1.855e-11, No Iterations 2
max(U) 1.53422e+65
GAMG:  Solving for p, Initial residual = 1.99619e-05, Final residual = 3.99114e-18, No Iterations 1
Predicted p max-min : 4.9197e+10 -9.75485e+126
max-min gamma: 1 0
Phase-change corrected p max-min : 4.9197e+10 -9.75485e+126
max(U) 1.53422e+65
GAMG:  Solving for p, Initial residual = 5.07469e-05, Final residual = 5.54335e-18, No Iterations 1
Predicted p max-min : 4.9197e+10 -9.75478e+126
max-min gamma: 1 0
Phase-change corrected p max-min : 4.9197e+10 -9.75478e+126
max(U) 1.53422e+65
DILUPBiCG:  Solving for omega, Initial residual = 0.0591393, Final residual = 2.52565e-12, No Iterations 2
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#3  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#5  Foam::fvMatrix<double>::solve() in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/cavitatingFoam"
#6  Foam::incompressible::RASModels::kOmegaSST::correct() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
What do these terms mean exactly? What could be cause of this?
I show the fvSolution settings if the problem was there:
solvers
    rho
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-08;
        relTol          0.1;
    rhoFinal
        solver          PBiCG;
        tolerance       1e-08;
        relTol          0;
    p
        solver          GAMG;
        tolerance       0;
        relTol          0.1;
        smoother        GaussSeidel;
        nPreSweeps      0;
        nPostSweeps     2;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator    faceAreaPair;
        mergeLevels     1;
    pFinal
        $p;
        tolerance       1e-08;
        relTol          0;
    "(U|k|omega)"
        solver          PBiCG;
        tolerance       1e-08;
        relTol          0.1;
    "(U|k|omega)Final"
        solver          PBiCG;
        tolerance       1e-08;
        relTol          0;
PIMPLE
    nCorrectors     3;
    nNonOrthogonalCorrectors 0;
Regarding turbulence models, I tested with laminar, RAS, and LES model but the same problem appear in all cases.
Thanks and regards,
Alvaro.
Old   June 3, 2015, 06:18
Al_th
al_th is on a distinguished road
Hi alvariten,
I notice something strange about your boundary condition. Even before being interested in the mesh, or the laminar/turbulent scheme.
You impose a pressure at the inlet, but you are saying that the velocity is fixed at (0 0 0). But isn't your goal to let fluid go through the inlet ?
If so, the velocity cannot be an uniform fixed value (0 0 0) and I would recommand you to change the U field for the inlet to type zeroGradient;
al_th is offline   Reply With Quote
Old   June 3, 2015, 20:43
alvaro
Hi Al_th,
I'm still learning in field of OpenFoam so I'm grateful that you advice me. What you propose makes sense. I have tried with zeroGradient at inlet and outlet but the error still appears.
Yes, my goal is impose varying pressure values over time (with uniformTotalPressrue) at inlet and fixed values at outlet with the purpose to get the mass flow through the output. The velocity is unknown so the best option is to set type zeroGradient.
I have no idea where is the mistake but I am struck by the warning message "FOAM Warning : From function Time:perator++()". This is related to the Co number and it means the time precision is increase while deltaT become too small, isn't it? Could be this the reason of the problem?
GAMG:  Solving for p, Initial residual = 0.000137488, Final residual = 4.00266e-17, No Iterations 1
Predicted p max-min : 2.17415e+09 -704709
max-min gamma: 1 0
Phase-change corrected p max-min : 2.17415e+09 29.1545
max(U) 1.17523e+106
GAMG:  Solving for p, Initial residual = 0.000160614, Final residual = 4.01508e-17, No Iterations 1
Predicted p max-min : 2.17415e+09 -773613
max-min gamma: 1 0
max(U) 1.17523e+106
GAMG:  Solving for p, Initial residual = 0.000135725, Final residual = 4.05313e-17, No Iterations 1
Predicted p max-min : 2.17415e+09 -878458
max-min gamma: 1 0
max(U) 1.17523e+106
ExecutionTime = 372.39 s  ClockTime = 446 s
phiv Courant Number mean: 6.053e-06 max: 0.550988 acoustic max: 3.23685e-103
deltaT = 1.86875e-112
--> FOAM Warning :
    From function Time::operator++()
    in file db/Time/Time.C at line 1010
    Increased the timePrecision from 1339 to 1340 to distinguish between timeNames at time 3.95078e-06
Time = 3.950780097946136277327518204760536946196225471794605255126953125e-06
DILUPBiCG:  Solving for rho, Initial residual = 3.68513e-05, Final residual = 1.19211e-09, No Iterations 2
max-min rho: 3784.75 -1.81282
max-min gamma: 1 0
DILUPBiCG:  Solving for Ux, Initial residual = 0.00088791, Final residual = 2.56648e-11, No Iterations 3
I have changed (decreased) the maxCo and max AcousticCo but the only I've done with this is to extend the time until crash...
What else I can do?
Regards.
Old   June 3, 2015, 21:04
alvaro
By the by, I would like to change the title of the thread because it no longer reflects well the topic to solve but I don't know how...
Old   June 4, 2015, 04:51
Al_th
Dear alvariten,
Don't worry, I'm also an Openfoam newbie (2/3 months only)
Yes, what you are saying is true, it looks like your Courant number blows up, and that the dynamic delatT (I am assuming you are using adjustTimeStep in your controlDict file) is getting smaller and smaller in order to respect your maxCo condition.
From what I've learned, if the Courant number blows up, it is not always (in my case, pretty much never) a problem of actually setting up deltaT. Especially when you use adjustTimeStep that is keeping an ideal deltaT at all time (until it blows up).
What I am suggesting here, is that when the problem happens, it causes the Courant number to blow up, but the problem itself is caused by something else (non physical boundary conditions have a nice tendency to make everything crash pretty fast).
Could you attach your case to the post so we can try it out ?
PS : In the meantime, what you could do is to try to reduce the pressure gradient (set the inlet pressure to something really close to the outlet, see if it crashes or of the solution seems to converge, and increase it gradually.
Old   June 4, 2015, 07:40
alvaro
Dear Al_th,
Here I show more details about the case:
- Geometry mesh (2D -> 2 input and 1 output)
(I've changed mesh)
- checkMesh log:
Create time
Time = 0
Mesh stats
    internal points:  0
    faces:            112969
    internal faces:   55641
    cells:            28080
    boundary patches: 5
    point zones:      0
    face zones:       0
    cell zones:       0
    hexahedra:     27958
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     122
    Point usage OK.
    Face vertices OK.
Checking patch topology for multiply connected surfaces ...
    inlet               60       124      ok (non-closed singly connected)
    outlet              72       146      ok (non-closed singly connected)
    nozzleWall          218      438      ok (non-closed singly connected)
    fixedWall           818      1640     ok (non-closed singly connected)
    frontback           56160    57460    ok (non-closed singly connected)
    Overall domain bounding box (-0.00081733 0 -1e-05) (0.00081733 0.00202762 1e-05)
    Mesh (non-empty, non-wedge) directions (1 1 0)
    Mesh (non-empty) directions (1 1 0)
    All edges aligned with or perpendicular to non-empty directions.
    Boundary openness (-4.75227e-18 2.00089e-17 2.02558e-15) OK.
    Max cell openness = 5.78434e-16 OK.
    Max aspect ratio = 7.27553 OK.
    Minumum face area = 1.38739e-12. Maximum face area = 7.66506e-10.  Face area magnitudes OK.
    Min volume = 2.77478e-17. Max volume = 1.53301e-14.  Total volume = 1.8426e-11.  Cell volumes OK.
    Mesh non-orthogonality Max: 47.2926 average: 12.1634
    Face pyramids OK.
    Max skewness = 3.41278 OK.
Mesh OK.
End
- Solver output:
cavitatingFoam log file
- Numerical settings:
controlDict
fvScheme
fvSolution
- BC's from 0 folder:
p
pinlet file
    (0         3410000)
    (0.00042  18130000)
U
(the case run in laminar model, but these are the set values for LESModel)
k
nuSgs
And it's all I think. If I have leave something, let me know.
Thanks for the interest.
Regards.
Old   June 8, 2015, 05:59
Hi Kate,
0/p
boundaryField
    frontback
        type            empty;
    inlet
        type            totalPressure;
        U               U;
        phi             phiv;
        rho             rho;
        psi             none;
        gamma           1;
        p0              uniform 150e5;
    outlet
        type            fixedValue;
        value           uniform 1e5;
    nozzleWall
        type            zeroGradient;
    fixedWall
        type            zeroGradient;
0/U
    frontback
        type            empty;
    inlet
    outlet
        type            inletOutlet;
    nozzleWall
        type            fixedValue;
    fixedWall
        type            fixedValue;
max-min gamma: 1 0
max(U) 1.53422e+65
max-min gamma: 1 0
max(U) 1.53422e+65
max-min gamma: 1 0
max(U) 1.53422e+65
solvers
    rho
        solver          PBiCG;
        tolerance       1e-08;
        relTol          0.1;
    rhoFinal
        solver          PBiCG;
        tolerance       1e-08;
        relTol          0;
    p
        solver          GAMG;
        tolerance       0;
        relTol          0.1;
        nPreSweeps      0;
        nPostSweeps     2;
        mergeLevels     1;
    pFinal
        $p;
        tolerance       1e-08;
        relTol          0;
    "(U|k|omega)"
        solver          PBiCG;
        tolerance       1e-08;
        relTol          0.1;
    "(U|k|omega)Final"
        solver          PBiCG;
        tolerance       1e-08;
        relTol          0;
PIMPLE
    nCorrectors     3;
Thanks and regards,
Alvaro.
Hi Alvaro,
I am afraid I cannot help you here. Nethertheless I have two remarks:
1) I think the max-min rho etc. outputs are no problem per se. But regarding the values I can't judge them because I'm not familiar with these types of simulations.
2) I would try to run the calculation with turbulence turned off. This way you can be sure the problem's not turbulence related.
Keep us updated,
Kate
Old   June 8, 2015, 11:31
Al_th
Dear Alvariten.
I do not see anything unusual in what you gave me (Note that in your last post, half your links were pointing on the controlDict file !)
Could you upload the full case so I can investigate ?
Old   June 8, 2015, 15:00
Default Nozzle 2D cavitaingFoam divergence
  #19
alvaro
Dear Alvariten.
Ops... it's true, sorry. I should check the links before post it.
I've fixed it!
PD: I would like to change the main thread title (to "Nozzle 2D cavitatingFoam divergence" ) I think it's the right thing and it describes current topic better. But I don't find the way to do it. Is it possible to change by myself or is an Administrator/Moderator who has to do it?
Regards.
Old   July 2, 2015, 04:10
sagar gurnani
sagarg is on a distinguished road
Dear Alvariten,
How did you fixed your divergence problem.. could you please explain.. I am facing similar issues.
Thanks
sagarg is offline   Reply With Quote
cavitatingfoam, divergence
simpleFoam: case only converges with most div schemes set to upwind buffi OpenFOAM Running, Solving & CFD 7 November 11, 2013 08:54
How to copy the simpleFoam case to turboFoam sivakumar OpenFOAM Pre-Processing 5 November 18, 2009 03:49
snappyMesh Motor Bike case for simpleFoam solver s.sivakumar OpenFOAM Running, Solving & CFD 0 July 22, 2009 09:00
Restart of case crashes feijooos OpenFOAM Running, Solving & CFD 0 July 21, 2009 12:04
Running a case with simpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 4 March 28, 2008 08:13
