cyclicAMI ... but only sometimes!
Old   April 10, 2015, 12:29
Default cyclicAMI ... but only sometimes!
Chris Meyer
chris_j_meyer is on a distinguished road
Hi All
Not entirely sure where this thread belongs ....
I define a pair of cyclicAMI boundarys primarily as I am sticking two meshes together where stichMesh refuses to work. The cyclicAMI pair is basically used to transfer information between two identical surfaces on two meshes but with non-matching cell-faces. Let's say one face has triangular and the other rectangular cell faces, but the two surfaces are otherwise congruent.
So for my basic fluid flow calculation this works fine. However, I solve an additional equation BUT for this equation the two cyclicAMI boundaries need to have separate fixed values for argument's sake and I thus do not want the boundaries to act as cyclicAMI boundaries.
Of course I define this pair as cyclicAMI in the boundary file in the "constant" directory. Severe complaints and misgivings are communicated by the solver should I dare to change these boundaries in the appropriate variable file to fixedValue or anything else.
I have tried some rather silly strategies (two boundary names for the same group of cell faces etc) but with no success, I have wondered if somebody has had a similar requirement.
chris_j_meyer is offline   Reply With Quote
Old   April 16, 2015, 04:40
W.T
dybuk is on a distinguished road
Did you try a mapped boundary condition ? It can act as an AMI BC but you can assign other BC (for example fixedValue). You can find example in tutorials/pisoFoam/les/pitzDailyMaped.
dybuk is offline   Reply With Quote
cyclicAMI get separated after floating chun OpenFOAM Running, Solving & CFD 1 March 19, 2015 10:11
Boundary Layer strange result fernexda OpenFOAM Running, Solving & CFD 14 January 15, 2015 08:21
problem with cyclicAMI and wall distance Maff OpenFOAM Bugs 5 August 14, 2014 15:41
CyclicAMI Boundary Condition CUBoulderPhDStudent OpenFOAM Running, Solving & CFD 0 May 21, 2014 19:34
CyclicAMI Issue In OpenFOAM 2.2.0 prasant OpenFOAM Running, Solving & CFD 17 March 16, 2013 03:00
