Rotational oscillations of 2D cube in water.
Old   April 10, 2015, 11:37
Default Rotational oscillations of 2D cube in water.
Alexander Lavrov
lavrov is on a distinguished road
I try to model roll (rotational oscillations) of 2D cube in water. I created the case. It is shown in attachment. I used tutorial slashingTank3D6DoF to create my case. The main original features are in the subroutines
pointMotionU
and
dynamicMeshDict
In the beginning I modelled heave and sway oscillation of the cube. It seems to me that the case is working for heave and sway without problems.
Array that dictates cube movement consists of 7 columns (time, displacement velocity in X, Y, Z directions, rotation velocity in X, Y, Z directions).
I cannot understand the dimension of the VALUE of rotational oscillation velocity. When I see the results in paraFoam it is obvious that if I increase the rotational velocity two times, the amplitude of rotational oscillations do not increase two times.
Dear forum participants. Thank you very much in advance for your help.
Alexander Lavrov, Lisbon, IST.
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
// object dynamicMeshDict;
object motionProperties; // old
dynamicFvMesh dynamicMotionSolverFvMesh;
motionSolverLibs ("libsixDoFRigidBodyMotion.so");
solver velocityLaplacian;
velocityLaplacianCoeffs
diffusivity inverseDistance (form);
| \\ / O peration | Version: 1.5 |
| \\ / A nd | Web: http://www.openfoam.org |
FoamFile
version 2.0;
format ascii;
class pointVectorField;
object pointMotionU;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
tank
type zeroGradient;
form
type solidBodyMotionDisplacement;
solidBodyMotionFunction tabulated6DoFMotion;
tabulated6DoFMotionCoeffs
CofG (600 0 0.25);
timeDataFileName "$FOAM_CASE/constant/150407_AMPL_10_4_PERIODS.txt";
atmosphere
type fixedValue;
value uniform (0 0 0);
front
type empty;
back
type empty;
lavrov is offline   Reply With Quote
2d flow, dynamic mesh, roll motion, slashingtank
Mass imbalance problem in multiphase water and steam CFX case Antech CFX 1 October 26, 2020 05:03
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Numerical oscillations in CFX with water boiling problem. michujo CFX 4 December 16, 2011 10:00
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
