problem during mpi in server: expected Scalar, found on line 0 the word 'nan'
Old   April 9, 2015, 06:12
Default problem during mpi in server: expected Scalar, found on line 0 the word 'nan'
mohammed musthafa
muth is on a distinguished road
am getting an error as given below while running in parallel in server.please help me to solve this
Warning: Permanently added 'aggra581,90.3.3.181' (RSA) to the list of known hosts.
[8]
[8]
[8] --> FOAM FATAL IO ERROR:
[8] wrong token type - expected Scalar, found on line 0 the word 'nan'
[8]
[10]
[10]
[10] --> FOAM FATAL IO ERROR:
[10] wrong token type - expected Scalar, found on line 0 the word 'nan'
[10]
[10] file: /home/usr1803/rakeshc/cases/pcis/processor10/system/data.solverPerformance.p_rgh at line 0.
[11]
[11]
[11] --> FOAM FATAL IO ERROR:
[11] wrong token type - expected Scalar, found on line 0 the word 'nan'
[11]
[11] file: /home/usr1803/rakeshc/cases/pcis/processor11/system/data.solverPerformance.p_rgh at line 0.
[11]
[11]     From function operator>>(Istream&, Scalar&)
[11]     in file [0]
[0]
[0] --> FOAM FATAL IO ERROR:
[0] wrong token type - expected Scalar, found on line 0 the word 'nan'
[0]
[0] file: /home/usr1803/rakeshc/cases/pcis/processor0/system/data.solverPerformance.p_rgh at line 0.
[0]
[0]     From function operator>>(Istream&, Scalar&)
[0]     in file lnInclude/Scalar.C at line 91.
[0]
FOAM parallel run exiting
[0]
[3]
[3]
[3] --> FOAM FATAL IO ERROR:
[3] wrong token type - expected Scalar, found on line 0 the word 'nan'
[3]
[3] file: /home/usr1803/rakeshc/cases/pcis/processor3/system/data.solverPerformance.p_rgh at line 0.
[3]
[3]     From function operator>>(Istream&, Scalar&)
[3]     in file lnInclude/Scalar.C at line 91.
[3]
[3]
[4]
[4]
[4] --> FOAM FATAL IO ERROR:
[4] wrong token type - expected Scalar, found on line 0 the word 'nan'
[4]
[4] file: /home/usr1803/rakeshc/cases/pcis/processor4/system/data.solverPerformance.p_rgh at line 0.
[4]
[4]     From function operator>>(Istream&, Scalar&)
[4]     in file lnInclude/Scalar.C at line 91.
[4]
[4]
[16]
[16]
[16] --> FOAM FATAL IO ERROR:
[16] wrong token type - expected Scalar, found on line 0 the word 'nan'
[16]
[16] file: /home/usr1803/rakeshc/cases/pcis/processor16/system/data.solverPerformance.p_rgh at line 0.
[16] [1]
[1]
[1] --> FOAM FATAL IO ERROR:
[1] wrong token type - expected Scalar, found on line 0 the word 'nan'
[1]
[1] file: /home/usr1803/rakeshc/cases/pcis/processor1/system/data.solverPerformance.p_rgh at line 0.
[1]
[1]     From function operator>>(Istream&, Scalar&)
[1]     in file lnInclude/Scalar.C at line 91.
[1]
[1]
[2]
[2]
[2] --> FOAM FATAL IO ERROR:
[2] wrong token type - expected Scalar, found on line 0 the word 'nan'
[2]
[2] file: /home/usr1803/rakeshc/cases/pcis/processor2/system/data.solverPerformance.p_rgh at line 0.
[2]
[2]     From function operator>>(Istream&, Scalar&)
[2]     in file lnInclude/Scalar.C at line 91.
[2]
[2]
[5]
[5]
[5] --> FOAM FATAL IO ERROR:
[5] wrong token type - expected Scalar, found on line 0 the word 'nan'
[5]
[5] file: /home/usr1803/rakeshc/cases/pcis/processor5/system/data.solverPerformance.p_rgh at line 0.
[5]
[5]     From function operator>>(Istream&, Scalar&)
[5]     in file lnInclude/Scalar.C at line 91.
[5]
[5]
[6]
[6]
[6] --> FOAM FATAL IO ERROR:
[6] wrong token type - expected Scalar, found on line 0 the word 'nan'
[6]
[6] file: /home/usr1803/rakeshc/cases/pcis/processor6/system/data.solverPerformance.p_rgh at line 0.
[6]
[6]     From function operator>>(Istream&, Scalar&)
[6]     in file lnInclude/Scalar.C at line 91.
[6]
[6]
[11]
[11]
[9]
[9]
[9] --> FOAM FATAL IO ERROR:
[9] wrong token type - expected Scalar, found on line 0 the word 'nan'
[9]
[9] file: /home/usr1803/rakeshc/cases/pcis/processor9/system/data.solverPerformance.p_rgh at line 0.
[9]
[9]     From function operator>>(Istream&, Scalar&)
[9]     in file lnInclude/Scalar.C at line 91.
[9]
[9]
[8] file: /home/usr1803/rakeshc/cases/pcis/processor8/system/data.solverPerformance.p_rgh at line 0.
[8]
[8]     From function operator>>(Istream&, Scalar&)
[8]     in file lnInclude/Scalar.C at line 91.
[8]
[8]
[10]
[10]     From function operator>>(Istream&, Scalar&)
[10]     in file lnInclude/Scalar.C at line 91.
[10]
[10]
[17]
[17]
[17] --> FOAM FATAL IO ERROR:
[17] wrong token type - expected Scalar, found on line 0 the word 'nan'
[17]
[17] file: /home/usr1803/rakeshc/cases/pcis/processor17/system/data.solverPerformance.p_rgh at line 0.
[17]
[17]     From function operator>>(Istream&, Scalar&)
[17]     in file lnInclude/Scalar.C at line 91.
[17]
[17]
[18]
[18]
[18] --> FOAM FATAL IO ERROR:
[18] wrong token type - expected Scalar, found on line 0 the word 'nan'
[18]
[18] file: /home/usr1803/rakeshc/cases/pcis/processor18/system/data.solverPerformance.p_rgh at line 0.
[18]
[18]     From function operator>>(Istream&, Scalar&)
[18]     in file lnInclude/Scalar.C at line 91.
[18]
[18]
[19]
[19]
[19] --> FOAM FATAL IO ERROR:
[19] wrong token type - expected Scalar, found on line 0 the word 'nan'
[19]
[19] file: /home/usr1803/rakeshc/cases/pcis/processor19/system/data.solverPerformance.p_rgh at line 0.
[19]
[19]     From function operator>>(Istream&, Scalar&)
[19]     in file lnInclude/Scalar.C at line 91.
[19]
[19]
[20]
[20]
[20] --> FOAM FATAL IO ERROR:
[20] wrong token type - expected Scalar, found on line 0 the word 'nan'
[20]
[20] file: /home/usr1803/rakeshc/cases/pcis/processor20/system/data.solverPerformance.p_rgh at line 0.
[20]
[20]     From function operator>>(Istream&, Scalar&)
[20]     in file lnInclude/Scalar.C at line 91.
[20]
[20]
[7] [21]
[21]
[21] --> FOAM FATAL IO ERROR:
[21] wrong token type - expected Scalar, found on line 0 the word 'nan'
[21]
[21] file: /home/usr1803/rakeshc/cases/pcis/processor21/system/data.solverPerformance.p_rgh at line 0.
[21]
[21]     From function operator>>(Istream&, Scalar&)
[21]     in file lnInclude/Scalar.C at line 91.
[21]
[21]
[7]
[7] --> FOAM FATAL IO ERROR:
[7] wrong token type - expected Scalar, found on line 0 the word 'nan'[22]
[22]
[22] --> FOAM FATAL IO ERROR:
[22] wrong token type - expected Scalar, found on line 0 the word 'nan'
[22]
[22] file: /home/usr1803/rakeshc/cases/pcis/processor22/system/data.solverPerformance.p_rgh at line 0.
[22]
[22]     From function operator>>(Istream&, Scalar&)
[22]     in file lnInclude/Scalar.C at line 91.
[22]
[22]
[7]
[7] file: /home/usr1803/rakeshc/cases/pcis/processor7/system/data.solverPerformance.p_rgh at line 0.
[7]
[7]     From function operator>>(Istream&, Scalar&)
[7]     in file [23]
[23]
[23] --> FOAM FATAL IO ERROR:
[23] wrong token type - expected Scalar, found on line 0 the word 'nan'
[23]
[23] file: /home/usr1803/rakeshc/cases/pcis/processor23/system/data.solverPerformance.p_rgh at line 0.
[23]
[23]     From function operator>>(Istream&, Scalar&)
[23]     in file lnInclude/Scalar.C at line 91.
[23]
[23]
[12]
[12]
[12] --> FOAM FATAL IO ERROR:
[12] wrong token type - expected Scalar, found on line 0 the word 'nan'
[12]
[12] file: /home/usr1803/rakeshc/cases/pcis/processor12/system/data.solverPerformance.p_rgh at line 0.
[12]
[12]     From function operator>>(Istream&, Scalar&)
[12]     in file lnInclude/Scalar.C at line 91.
[12]
[12]
[7]
[7]
[13] [14]
[14]
[14] --> FOAM FATAL IO ERROR:
[14] wrong token type - expected Scalar, found on line 0 the word 'nan'
[14]
[14] file: /home/usr1803/rakeshc/cases/pcis/processor14/system/data.solverPerformance.p_rgh at line 0.
[14]
[14]     From function operator>>(Istream&, Scalar&)
[14]     in file lnInclude/Scalar.C at line 91.
[14]
[14]
[15]
[15]
[15] --> FOAM FATAL IO ERROR:
[15] wrong token type - expected Scalar, found on line 0 the word 'nan'
[15]
[15] file: /home/usr1803/rakeshc/cases/pcis/processor15/system/data.solverPerformance.p_rgh at line 0.
[15]
[15]     From function operator>>(Istream&, Scalar&)
[15]     in file lnInclude/Scalar.C at line 91.
[15]
[15]
[16]     From function operator>>(Istream&, Scalar&)
[16]     in file lnInclude/Scalar.C at line 91.
[16]
[16]
[13]
[13] --> FOAM FATAL IO ERROR:
[13] wrong token type - expected Scalar, found on line 0 the word 'nan'
[13]
[13] file: /home/usr1803/rakeshc/cases/pcis/processor13/system/data.solverPerformance.p_rgh at line 0.
[13]
[13]     From function operator>>(Istream&, Scalar&)
[13]     in file lnInclude/Scalar.C at line 91.
[13]
[13]
MPI_ABORT was invoked on rank 3 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[aggra583.compunet.barc.in:15230] 23 more processes have sent help message help-mpi-api.txt / mpi-abort
[aggra583.compunet.barc.in:15230] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Warning: Permanently added 'aggra583,90.3.3.183' (RSA) to the list of known hosts.
muth is offline   Reply With Quote
Old   April 9, 2015, 17:08
Retired Super Moderator
Bruno Santos
Greetings muth and welcome to posting on the forum!
The error message seems to be clear enough that a "nan" value has been read from a file. As for what "nan" means: http://en.wikipedia.org/wiki/NaN
Beyond this, it's almost impossible to deduce what went wrong. Please follow these instructions: http://www.cfd-online.com/Forums/ope...-get-help.html
Best regards,
Bruno
Old   April 10, 2015, 06:42
mohammed musthafa
thank you for your kind suggestion.
Old   August 27, 2018, 05:18
Foad
foadsf is on a distinguished road
This error arises in non-MPI problems as well and the reducing the deltaT in controlDict seems to resolve the issue. I learned this from here.
foadsf is offline   Reply With Quote
Diverging solution in transonicMRFDyMFoam tsalter OpenFOAM Running, Solving & CFD 30 July 7, 2014 07:20
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
