reactingFoam, strange behavior, bug ?
Old   April 6, 2015, 06:58
Question reactingFoam, strange behavior, bug ?
Mieszko Młody
ziemowitzima is on a distinguished road
Dear All,
I encountered, a very strange behavior, which I hope could be explained with help of other Foamers.
I am running calculations using reactingFoam, but without reactions and combustions. I am interested in passive gas mixing.
The problem is:
I run the same calculations (exacly the same set-up, mesh, etc.) with two different max Courant Number:
1. maxCo = 2
and
2. maxCo = 0.25
I would expect that calculations with maxCo = 0.25 should be more numerically stable and give more presice results, because dt is smaller.
BUT
-results for maxCo = 0.25 are numerically unstable, they blew up after some time,
- results for maxCo = 2 are stable and gives nice smooth results...
Attached are results, which show O2 content in few points of the domain. They are compared with some experimental results.
Why for maxCo = 0.25 results are so different and so "bad", and why does it blew up ?
here results with maxCo = 2
Here results with MaxCo = 0.25
Thanks,
ZMM
ziemowitzima is offline   Reply With Quote
Old   April 7, 2015, 05:39
Markus Rehm
markusrehm is on a distinguished road
it has been a long time since I have bee using reactingFoam. I guess that there is a problem with the chemical time scales and or the ODE-Solver.
Might be that the reactions have not really started and after each time step they are averaged. Which ODE-Solver are you using?
Maybe you can check your mechanism in chemfoam?
Regards, Markus.
markusrehm is offline   Reply With Quote
Old   April 7, 2015, 07:53
Mieszko Młody
Hi Markus,
Thank you for your interest !
In my case I do NOT use chemical reactions, just passive mixing.
But in the chemistryProperties I have:
chemistrySolver ode;
but later:
chemistry off;
Regards,
ZMM
Old   April 8, 2015, 07:59
Markus Rehm
I remember that there was an issue with the diffusion terms even leading to wrong temperature. But as mentioned above I haven' t used the solver for a long time.
Maybe that helps:
http://www.cfd-online.com/Forums/ope...-update-2.html
Good luck.
Markus
bug?, courant number, reactingfoam
How to switch off combustion and reaction in reactingFoam shenzhou1987 OpenFOAM Running, Solving & CFD 16 October 26, 2017 16:31
calculate flame speed using reactingFoam IColin OpenFOAM Running, Solving & CFD 0 February 4, 2014 16:14
reactingFoam wedge handling wrong U dhondupant OpenFOAM Bugs 1 December 9, 2010 08:34
reactingFoam - turbulent reacting flow hamburgFoam OpenFOAM 0 December 7, 2009 13:57
Strange incorrect inlet behavior for reactingFoam mrangitschdowcom OpenFOAM Running, Solving & CFD 4 August 29, 2007 16:55
