April 5, 2015, 15:31 |
Lagrangian particle Track
iman vasefi
Rep Power: 16 |
Dear Foamers
I want to simulate the particle track in a steady incompressible flow and I want to consider two way coupling between particles and base fluid by adding different forces such as lift,drag and Brownian. could you help me which solver is appropriate for this lagrangian particle track? thank you in advance |
June 2, 2016, 21:39 |
#2 | |
Ping Chang
Rep Power: 10 |
I think DPMFoam could meet your requirement. Cheers. |
June 3, 2016, 01:46 |
Bijan Darbari
Rep Power: 10 |
Dear elah599
you can use "dpmfoam" solver. but this solver don't solve heat transfer equation. so the brownian force can't be acitvated. If you want to solve heat transfer equation and brownian force, use "reactingparcelfoam" and deactivate combustion, chemistry, evapoartion,... to solve a two way lagrangian solid particle with eulerian single phase fluid. If you have more questions ask me! |
June 3, 2016, 07:35 |
#4 | |
Evangelos
Rep Power: 14 |
I think that brownian force doesn't work as is supposed.
It seems the brownian force overcomes the paramagnetic force and this is not true. Under the magnetic force the magnetic nanoparticles are formed into chains. With the brownian force activated the particles are moving very fast and the magnetic force seems not to affect at all the particles. Many of these are are lost after some iterations. Quote:
June 3, 2016, 12:46 |
#5 | |
Ping Chang
Rep Power: 10 |
The reactingparcelFoam cannot simulate incompressible fluid and the collision between particles . And the DOMFoam cannot solve the dilute phase I think. |
June 3, 2016, 14:56 |
#6 | |
Bijan Darbari
Rep Power: 10 |
Dear chpjz0391
the "dpmfoam" can solve flow with high concentration of particles but I think there is not any problem with dilute flow of particles. both "reactingparcelfoam" and "dpmfoam" use the same particle track class and the difference is submodels and eulerian phase equations. |
June 3, 2016, 19:30 |
#7 | |
Ping Chang
Rep Power: 10 |
Thanks for your reply. I will use the DPMForm to simulate the dilute particle phase and then compare the result with the reactingparcelFoam . |
[swak4Foam] Validation of swak4Foam for lagrangian particle tracking | nero235 | OpenFOAM Community Contributions | 13 | March 28, 2017 05:45 |
Lagrangian Particle Tracking in Eulerian-Eulerian Multiphase Flow | DarrenC | CFX | 5 | April 7, 2016 14:50 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
Particle track files | Sankalp | CFX | 1 | August 25, 2004 23:25 |
