Centrifugal Pump: cells with high values of pressure |
April 4, 2015, 09:47 |
Rep Power: 13 |
I'm running the analysis of a centrifugal pump in OF, the geometry is the same reported in the the Ansys.CFX tutorials "Chapter 28: Drop Curve for Cavitating Flow in a Pump". I have set the analysis with the SRFSimpleFoam solver, cyclicAMI condition for the periodicy and rotatingWall for the stationary-wall. After 1000 iterations, I noticed that some cells, near the intersection between the inlet and the shroud-wall, assume high value of pressure and velocity respect the correct field. I have also seen the error in another case. Is this a common error in OF? What can be the cause of the error? Thanks in advance, Dmaz |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
Too high values of temperature, pressure and velocity | valahian1 | FLUENT | 1 | July 1, 2015 03:53 |
How do I find the pressure head for centrifugal Pump | dsuneail | CFX | 1 | March 2, 2010 16:53 |
in Centrifugal pump, How can i get pressure? | daniel sin | FLUENT | 0 | March 9, 2006 01:08 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
