RenumberMesh causing divergence
Old   April 1, 2015, 19:33
Default RenumberMesh causing divergence
anonymous
altair279 is on a distinguished road
I am running a flow past a cylinder case in 3D in openfoam. The case runs fine without RenumberMesh utility but I wanted to use RenumberMesh utility to speed up the solution. When I use the RenumberMesh utility, the solution diverges (mainly omega, I am using k-omega SST model). Is there any particular reason for this?
P.s. When I used renumberMesh on the same case in 2D, everything ran fine.
Thanks in advance.
altair279 is offline   Reply With Quote
openfoam, renumbermesh
Floating Point Exception Error nyox FLUENT 11 November 30, 2018 13:31
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
Divergence problem Smaras FLUENT 13 February 21, 2013 06:03
3d vof Smaras FLUENT 2 February 19, 2013 07:58
Dynamic Grid Remeshing causing Divergence? Andrew Wick FLUENT 0 January 23, 2006 19:39
