April 1, 2015, 11:48 |
The liquid volume fraction is below zero
zhouhoucun
Rep Power: 11 |
Hello everyone,
I meet a problem when I use the interPhaseChangeFoam to solve cavitation. The liquid volume fraction sometimes is negative, why this happend and how to correct it. Thank you! Some part of the log file reads below: Time = 0.0056369 DILUPBiCG: Solving for alpha1, Initial residual = 1.98079e-08, Final residual = 2.35875e-13, No Iterations 1 Liquid phase volume fraction = 0.999986 Min(alpha1) = 3.67397e-08 Max(alpha1) = 1 GAMG: Solving for p_rgh, Initial residual = 2.28663e-07, Final residual = 8.71765e-10, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 1.88297e-08, Final residual = 6.29201e-10, No Iterations 1 time step continuity errors : sum local = 2.18658e-08, global = 5.46088e-10, cumulative = -7.63934e-05 GAMG: Solving for p_rgh, Initial residual = 7.47701e-08, Final residual = 4.65551e-10, No Iterations 1 GAMGPCG: Solving for p_rgh, Initial residual = 1.00922e-08, Final residual = 1.00922e-08, No Iterations 0 time step continuity errors : sum local = 2.18706e-08, global = 5.46088e-10, cumulative = -7.63929e-05 ExecutionTime = 80989.1 s ClockTime = 81112 s Courant Number mean: 0.00309833 max: 0.585979 Time = 0.0056374 DILUPBiCG: Solving for alpha1, Initial residual = 1.98261e-08, Final residual = 2.36535e-13, No Iterations 1 Liquid phase volume fraction = 0.999986 Min(alpha1) = -7.74337e-09 Max(alpha1) = 1 GAMG: Solving for p_rgh, Initial residual = 2.47487e-07, Final residual = 8.93709e-10, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 1.88038e-08, Final residual = 6.25815e-10, No Iterations 1 time step continuity errors : sum local = 2.18726e-08, global = 5.46324e-10, cumulative = -7.63923e-05 GAMG: Solving for p_rgh, Initial residual = 7.61096e-08, Final residual = 4.40814e-10, No Iterations 1 GAMGPCG: Solving for p_rgh, Initial residual = 9.04325e-09, Final residual = 9.04325e-09, No Iterations 0 time step continuity errors : sum local = 2.18767e-08, global = 5.46324e-10, cumulative = -7.63918e-05 ExecutionTime = 80990.9 s ClockTime = 81113 s Courant Number mean: 0.00309833 max: 0.585899 Time = 0.0056379 DILUPBiCG: Solving for alpha1, Initial residual = 1.98583e-08, Final residual = 2.37556e-13, No Iterations 1 Liquid phase volume fraction = 0.999986 Min(alpha1) = 4.10681e-08 Max(alpha1) = 1 GAMG: Solving for p_rgh, Initial residual = 2.46697e-07, Final residual = 8.71039e-10, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 1.89244e-08, Final residual = 6.30179e-10, No Iterations 1 time step continuity errors : sum local = 2.18737e-08, global = 5.46559e-10, cumulative = -7.63912e-05 GAMG: Solving for p_rgh, Initial residual = 7.57724e-08, Final residual = 4.73074e-10, No Iterations 1 GAMGPCG: Solving for p_rgh, Initial residual = 1.02177e-08, Final residual = 1.02177e-08, No Iterations 0 time step continuity errors : sum local = 2.18785e-08, global = 5.4656e-10, cumulative = -7.63907e-05 ExecutionTime = 80992.6 s ClockTime = 81115 s |
April 2, 2015, 01:21 |
#2 | |
Dear zhouhoucun, There could be many minor reasons related to CFD. But the major reason could be negative volumes: Check your mesh for the negative volumes, try removing it. - Best Luck! |
April 2, 2015, 02:04 |
#3 | |
zhouhoucun
Rep Power: 11 |
Thank you very much to reply my question, I will check the mesh carefully and try again. Yours, Zhou |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
volume fraction = nan | Virtual-iCFD | OpenFOAM Running, Solving & CFD | 8 | June 12, 2015 19:15 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 08:47 |
Liquid Fraction - Redefined | linus | FLUENT | 0 | December 16, 2006 09:36 |
the Eulerian model and the lower volume fraction | hx li | FLUENT | 2 | October 27, 2005 07:17 |
