twoPhaseEulerFoam bubble column crashes due to problems at outlet region
Old   March 30, 2015, 08:05
Default twoPhaseEulerFoam bubble column crashes due to problems at outlet region
hester is on a distinguished road
Hello everyone,
I'm investigating a water air bubble column in a cuboid after Deen.
When using more complex modells for the interface momentum transport coefficients I get problems at the outlet area (see pictures below). With SchillerNaumann for drag coefficient everything worked fine, while with IshiiZuber for drag coefficient the simulation crashes.
This is my case setup:
//========= 1. Mesh =============================//
The cuboid measurements are 0.15 m x 0.15 m x 0.45 m. The inlet at the bottom is modelled as rectangular. The water surface is not included.
I generated my mesh using blockMesh. It is equidistant. CheckMesh is okay.
//========= 2. Boundary conditions ==================//
I am using the following boundary condtitions:
alpha.air
internalField   uniform 0;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 1;
    outlet
        type            inletOutlet;
        phi             phi.air;
        inletValue      uniform 0;
        value           uniform 0;
    walls
        type            zeroGradient;
U.air
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            fixedValue;
        value           uniform (0 0 0.0784);
    outlet
        type            zeroGradient;
    walls
        type            fixedValue;
        value           uniform (0 0 0);
U.water
boundaryField
    inlet
        type            fixedValue;
    outlet
        type            slip;
    walls
        type            fixedValue;
p
internalField   uniform 100000;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           $internalField;
    walls
        type            zeroGradient;
k.*
internalField   uniform 1e-4;
boundaryField
    inlet
        type             turbulentIntensityKineticEnergyInlet;
        intensity       0.05;
        value            uniform 0;
    outlet
        type            inletOutlet;
        phi             phi.air;
        inletValue      $internalField;
        value           uniform 0;
    walls
        type            zeroGradient;
epsilon.air
internalField   uniform 1e-5;
boundaryField
    inlet
        type            turbulentMixingLengthDissipationRateInlet;
        mixingLength    1e-3;
        k               k.air;
        value           uniform 0;
    outlet
        type            inletOutlet;
        phi             phi.air;
        value           uniform 0;
    walls
        type            zeroGradient;
epsilon.water
boundaryField
    inlet
        type            fixedValue;
    outlet
        type            inletOutlet;
        phi             phi.water;
        value           uniform 0;
    walls
        type            zeroGradient;
//========= 3. Phase Properties =====================//
I'm assuming a constant air bubble diameter of 4 mm. I only consider drag, lift and virtual mass force. Drag is modelled after Ishii and Zuber as describes here:
http://cfd-online.com/Forums/openfoa...eulerfoam.html
Lift and virtual mass coefficents are both constant with a value of 0.5.
//========= 4. Discretization =======================//
Used methods in fvScheme
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    // from bubble column tutorial
    "div\(phi,alpha.*\)"        Gauss vanLeer;
    "div\(phir,alpha.*\)"       Gauss vanLeer
    "div\(alphaPhi.*,U.*\)"     Gauss limitedLinearV 1;
    "div\(phi.*,U.*\)"          Gauss limitedLinearV 1;
    "div\(alphaPhi.*,.*rho.*\)" Gauss linear;
    "div\(alphaPhi.*,(h|e).*\)" Gauss limitedLinear 1;
    "div\(alphaPhi.*,(K.*|p)\)" Gauss limitedLinear 1;
    "div\(alphaPhi.*,(k|epsilon).*\)"  Gauss limitedLinear 1;
    "div\(phim,(k|epsilon)m\)"    Gauss limitedLinear 1;
    "div\(\(\(alpha.*nuEff.*\)*dev2\(T\(grad\(U.*\)\)\)\)\)" Gauss linear;
laplacianSchemes
    default         Gauss linear uncorrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         uncorrected;
fluxRequired
    default         no;
    p               ;
//========= 5. Solution ===========================//
I only use GAMG as suggested by my professor.
fvSolution:
solvers
    alpha.air
        nAlphaCorr      1;
        nAlphaSubCycles 2;
    p
        solver          GAMG;
        smoother        DIC;
        nPreSweeps      0;
        nPostSweeps     2;
        nFinestSweeps   2;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 160;
        agglomerator    faceAreaPair;
        mergeLevels     2;
        tolerance       1e-6;
        relTol          0.0001;
    pFinal
        $p;
        relTol          0;
    "e.*"
        solver          GAMG;
        smoother        DILU;
        nPreSweeps      0;
        nPostSweeps     2;
        nFinestSweeps   2;
        mergeLevels     2;
        tolerance       1e-6;
        relTol          0.0001;
    "(k|epsilon|Theta).*"
        solver          GAMG;
        smoother        DILU;
        nPreSweeps      0;
        nPostSweeps     2;
        nFinestSweeps   2;
        mergeLevels     2;
        tolerance       1e-6;
        relTol          0.0001;
PIMPLE
    nOuterCorrectors 1;
    nCorrectors      2;
    nNonOrthogonalCorrectors 0;
    residualControl
        "(U|k|epsilon)"
            relTol          0.0001;
            tolerance       0.0001;
    turbOnFinalIterOnly off;
relaxationFactors
The used Co number is 0.3. The mixtureKEpsilon modell is applied.
//========= 6. Problem ===========================//
After air reaches the outlet area it didn't seem to leave. alpha.air gets big (still <1) in the upper cells and the solution eventually crashes shortly after 7.6 s flow. The flow field for U.water shows there is water inflow. I first set up my case using SchillerNaumann for drag and everything worked fine. But using IshiiZuber instead breaks my simulation. I already tried different things that I found on the forum:
  • setting turbulence setting to laminar: same problem, turbulence modell is not the problem
  • Co = 0.1 instead of 0.3: same problem, is just takes longer to crash
  • nCorrectors = 8 in PISO algorithm: same problem, is just takes much longer to crash
  • including the water surface: high velocities for air in area above water surface, simulation crashes
  • using 1st order discretization: same problem, athough simulation doesn't crash
I hope someone knows what might be the problem or even has encountered the problem already and knows how to deal with it. I've been struggling with this case for a while now. Any help is greatly appreciated.
Regards,
hester
hester is offline   Reply With Quote
Old   March 30, 2015, 09:47
Here are the source files of the used Ishii Zuber drag model.
Old   March 30, 2015, 17:00
Mattia de\' Michieli Vitturi
demichie is on a distinguished road
Hi Hester,
I am wondering why you are using a "slip" boundary condition at the outlet for the liquid velocity and not a "zeroGradient". Have you tested the zeroGradient?
Ciao
Mattia
demichie is offline   Reply With Quote
Old   March 31, 2015, 07:47
Hello Mattia,
thank you for your answer. I tried zeroGradient for the liquid face at the outlet. I get no simulation problems but the results were wrong. I didn't observe the recirculation pattern in the liquid face. Also was the velocity compared with experimental results too low. So zeroGradient is not what I want here. I use slip because the the outlet boundary is where the water surface would be if I included it in my simulation. I don't want any water to leave the domain.
Regards,
hester
Old   May 18, 2016, 11:20
BlnPhoenix is on a distinguished road
Originally Posted by hester View Post
Hello Mattia,
Regards,
hester
Hello Hester,
were you able to resolve your problem at the outlet region? I think the slip BC is OK to model water surface but i recognized you did not post your alpha.water file. What did you put there for outlet?
For the other approach, when i try to model water and air as two different parts in my domain via setFields i experience that even with a fine mesh the water/air interface (surface) becomes very fuzzy over time which i can not explain or resolve so far..
BlnPhoenix is offline   Reply With Quote
Old   July 21, 2024, 09:19
Default regarding to twophaseEulerfoam solver
omveer
om_veer is on a distinguished road
hello friend ,
now i am doing work on heat exchanger that in which used nanofluid used as a coolent so now i am try to doing solve governing equation in openFoam . and for this problem , choose twophaseEulerFoam but when i apply boundery condition according to desireable result and problem, than facing some problem an showing some error like
om_veer is offline   Reply With Quote
bubble column, twophaseeulerfoam
Solving bubble column using twoPhaseEulerFoam vishal3 OpenFOAM Pre-Processing 0 July 11, 2013 07:19
Some problems with twoPhaseEulerFoam su_junwei OpenFOAM Running, Solving & CFD 2 November 2, 2012 02:12
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
VOF Outlet boundary condition in cfd - ace JM Main CFD Forum 0 December 15, 2006 09:07
Bubble Column Glen Main CFD Forum 0 January 24, 2006 01:56
