March 20, 2015, 05:39 |
Gas mixing with air
Sture Smidt
Rep Power: 13 |
I am going to solve a gas plume mixing with air. The domain will be at least 1000m long over a fairly flat surface. The gas will be let into the domain through a inlet flush with the surface (ground). The air will be moving at, say, 10 m/s. The interesting result is the gas to air ratio as a function of time and distance. Which solvers are candidates? Best Regards Sture |
intake/inlet air filter in gas turbine power plant | zenwalk | ANSYS | 0 | May 3, 2014 21:44 |
Mixing of water and gas ? | blackcentipede91 | FLUENT | 0 | September 22, 2013 04:15 |
Fuel + Air mixing | Daniellvf | AVL FIRE | 1 | March 28, 2013 09:47 |
ideal gas mixing law and mass-weighted mixing law | Shankar | FLUENT | 0 | June 24, 2003 14:25 |
How to define the mixture of air and other gas? | dxmgws | FLUENT | 5 | March 21, 2003 17:03 |
