pressure plot mild oscillations in 2D airfoil simulation with simplefoam(parallel) |
March 19, 2015, 21:24 |
Bhanu
Rep Power: 12 |
Dear all,
I am doing simulations of 2D incompressible turbulent flow over NACA 2412 airfoil as part of my Master Thesis. I am absolutely stuck at a point to find separation point to introduce some active flow control. I can see the separation from velocity magnitude in paraview(image attached for angle of attack 11). But when I plot XY graphs in pressure and wall shear stress in paraview it gives a weird pattern and hides the point. The specific case was run in 8 cores. Reynolds number : 3.1 *10 ^6 Turbulence Model : kkLOmega with turbulent intensity(I) 0.06 and viscosity ratio (vt)0.01 for calculating kt {1.5(I*u)^2} and omega {k/nu *vt } Wall functions are not used. Max yPlus initial and after final iteration are managed to be close to 1 with the mesh HTML Code:
Writing yPlus to field yPlus Time = 20000 Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RASModel Selecting RAS turbulence model kkLOmega bounding kt, min: 0 max: 305.053 average: 2.07085 bounding kl, min: 0 max: 467.602 average: 1.88121 bounding omega, min: 0 max: 47777.5 average: 280.85 kkLOmegaCoeffs { A0 4.04; As 2.12; Av 6.75; Abp 0.6; Anat 200; Ats 200; CbpCrit 1.2; Cnc 0.1; CnatCrit 1250; Cint 0.75; CtsCrit 1000; CrNat 0.02; C11 3.4e-06; C12 1e-10; CR 0.12; CalphaTheta 0.035; Css 1.5; CtauL 4360; Cw1 0.44; Cw2 0.92; Cw3 0.3; CwR 1.5; Clambda 2.495; CmuStd 0.09; Prtheta 0.85; Sigmak 1; Sigmaw 1.17; } Patch 0 named WALL_UP d : min: 1.25271e-06 max: 1.54599e-06 average: 1.35678e-06 y+ : min: 0.00778992 max: 0.814644 average: 0.0946178 Patch 1 named WALL_DOWN d : min: 1.11943e-06 max: 1.57132e-06 average: 1.319e-06 y+ : min: 0.00333455 max: 1.14329 average: 0.105871 Writing yPlus to field yPlus End I have attached the 0, system, properties in constant folder, mesh images in the following attachements. Some Information: I have tried first order, second order schemes for gradient, divergence and laplacian with converging residuals. I varied parameters in fvSOlution like residual control, relative tolerance and other solvers parameters. I played around with boundary conditions from zerogradient, fixed values, freestream for pressure and velocity. I did mesh dependency checks by changing max yPlus till 0.1. Time Step continuity errors are close to 10 ^-11. I can immediately provide most of such results if any of you would like to have some other perspectives. And this is a blunt airfoil. the cd and cl are properly converging for most of these changes and I can provide any of that data. My questions: 1. Is it something related to some post processing issues of reconstuct par near the wall ? Because the pattern of the jumps is once every 8 or 16 points(case is decomposed in 8 cores). I can provide csv format data or close up graph if you think it is. 2. Is it related to the initial pressure residual being high close to 10 ^-3 ? or Can I rely on the better converged final residuals ? 3. Any of the mesh issues ? 4. Can you suggest any other way to find separation point ? 5.Kindly suggest any of your ideas and I can try it out in the cluster and get back. Any help on this issue is deeply appreciated as I am stuck with from many days. Kindly let me know for any further details Regards, Bhanu |
March 19, 2015, 21:43 |
Bhanu
Rep Power: 12 |
Kindly forgive me and let me know if I made some errors in posting the thread and I can update with the same for next threads. Please find the other files here.
March 19, 2015, 21:44 |
Bhanu
Rep Power: 12 |
Mesh files
airfoil mesh genaration and simulation with a trip on surface issue | rajibroy | Mesh Generation & Pre-Processing | 1 | December 3, 2014 03:04 |
Transient simulation (Problem with massflow and Pressure) | ChristianF | CFX | 4 | August 22, 2011 22:42 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 03:15 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 23:02 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
