Wrong zone in MRF
Old   March 13, 2015, 19:07
Default Wrong zone in MRF
luca
luca1989 is on a distinguished road
Hi guys! I'm trying to simulate an rc EDF witch consist in a static part and a fan. I did the mesh in snappy (parallel) inserting under "geometry"
MRF1.stl
type triSurfaceMesh;
name MRF1;
and under "refinementSurfaces"
MRF1
level (8 8);
regions{}
faceZone MRF1;
cellZone MRF1;
zoneInside true;
the mesh runs good and at the end i can find the file cellzone and facezone in the folders constan of all the processors. I also put the following fvOption in the system folder
MRF1
type MRFSource;
active true;
selectionMode cellZone;
cellZone MRF1;
MRFSourceCoeffs
origin (-0.095 0 0);
axis (-1 0 0);
omega 300;
When I run potential foam and/or simplefoam al the domani outside the MRF zone is rotating and i don't know why.
Anyone have any suggestion? Thanks
luca1989 is offline   Reply With Quote
Old   March 14, 2015, 06:43
luca
I found a solution althought I don't understand the logic with cellZones are defined, so if anyone can explain me the reason why it works it will be very helpfull.
Anyway if I put in the definition of the cellzone "outside" instead of inside it works (the domain inside of the MRF1 surface rotates)
MRF1
level (7 7);
regions{}
faceZone MRF1;
cellZone MRF1;
cellZoneInside outside; //zoneInside true;
P.S. I also tried witing "cellZoneInside inside" but it leads to the same result of "zoneInside true" option. Again I can't understand what difference there's between "cellZoneInside" and "zoneInside", so any suggestion is appreciated.
mrf, openfoam, problem
rotating wall inside of an MRF zone - fixedValue or movingWallvelocity? evrikon OpenFOAM Running, Solving & CFD 3 April 30, 2015 04:51
cyclicAMI problem in MRF zone jmf OpenFOAM Running, Solving & CFD 8 August 14, 2014 14:48
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
Segmentation Fault in fluent3DMeshToFoam cwang5 OpenFOAM Bugs 23 April 13, 2011 16:37
help! sth wrong while reading case xuan FLUENT 1 May 21, 2007 03:01
